17255 Discussions
Quartus II giving me the wrong error?
Hey, uh, first time here, so yeah... bit nervous, but was wondering if someone could help me with this little problem? ._.
I've worked with Verilog and Quartus in the past, but recently stopped due to the weirdest error messages I've ever seen.
Now, bear in mind this is one of my first projects, and in this I've chosen the CPU route. It's not completely complex, but not completely simple. Code is in the attachment.
I've skimmed over it a thousand times, fixed, debugged, and rooted out the stuff that I thought was the cause. Nowhere did I find the mysterious bug. Errors are below:
Info: *******************************************************************
Info: Running Quartus II Functional Simulation Netlist Generation
Info: Version 7.2 Build 203 02/05/2008 Service Pack 2 SJ Full Version
Info: Processing started: Tue May 18 20:05:10 2010
Info: Command: quartus_map --read_settings_files=on --write_settings_files=off WK-2B -c WK-2B --generate_functional_sim_netlist
Info: Found 1 design units, including 1 entities, in source file TopLevel.bdf
Info: Found entity 1: TopLevel
Error (10170): Verilog HDL syntax error at WK-2B.v(524) near text ":"; expecting "<=", or "="
Error (10170): Verilog HDL syntax error at WK-2B.v(529) near text "default"; expecting "@", or "end", or an identifier ("default" is a reserved keyword ), or a system task, or "{", or a sequential statement
Error (10170): Verilog HDL syntax error at WK-2B.v(533) near text "endcase"; expecting "@", or "end", or an identifier ("endcase" is a reserved keyword ), or a system task, or "{", or a sequential statement
Error (10170): Verilog HDL syntax error at WK-2B.v(536) near text "end"; expecting "endcase", or an identifier ("end" is a reserved keyword ), or a number, or a system task, or "(", or "{", or unary operator
Info: Found 0 design units, including 0 entities, in source file WK-2B.v
Info: Found 1 design units, including 1 entities, in source file MemoryManager.v
Info: Found entity 1: MemoryManager
Error: Quartus II Functional Simulation Netlist Generation was unsuccessful. 4 errors, 0 warnings
Info: Allocated 164 megabytes of memory during processing
Error: Processing ended: Tue May 18 20:05:11 2010
Error: Elapsed time: 00:00:01
...*Ahem* What?
Please, please tell me, and please point it out if you see it. I don't wanna be bumbling around like an idiot here. X.x
Thanks for the help in advance, much obliged to you all! :)
~JW
Just looking at your code fairly quickly, it appears you are missing the "end" statement for the "if" that begins on line 127. After inserting an "end" statement at line 518, the code compiles.
Thanks. I tried to match up every if statement with it's corresponding begin and end. Looks like I missed one.
~JW
