17253 Discussions
vcd file output in modelsim altera for power analysis
I am trying to generate vcd file in ModelSim.
For that i followed following steps
1 . Full Compilation of VHDL files ( excluding testbench.vhdl file) in quartus software, with selection of ModelSim Altera in EDA tool and DESIGN INSTANCE NAME as 'testbench' ( which is my testbench file name as well as testbench entity name).
2 The TCL file is copied to the folder where simulation is done using ModelSim, along with all vhdl files (including testbench file) . i am using testbench to do simulation .
3 With this i compiled and simulated the file and then loaded the tcl file using "source address_generator_dump_all_vcd_nodes.tcl " command.
then tried to run the simulation with run 5000 ns;
I expected "address_generator.vcd" file with some information. But
the file doesnot have any content in it before the simulation is closed.
When the simulation is closed, it only contain lines as below
"$date
Tue May 18 15:06:57 2010
$end
$version
ModelSim Version 6.4a
$end
$timescale
1ps
$end
I dont know what is the reason that i am not getting data in the vcd files.
Any help is appreciable
With regards
pasa
