17255 Discussions
Quartus II web edition licence problems.
it is mentioned in http://www.altera.com/products/software/quartus-ii/web-edition/qts-we-index.html that the web edition supports all max cplds
but when i downloaded the software and tried to do a simple vhdl project it didnt compile and gave me the following messeges:
Warning: FLEXlm software error: Invalid (inconsistent) license key The license-key and data for the feature do not match. This usually happens when a license file has been altered Feature: quartus License path: C:\altera\91\quartus\license.dat FLEXlm error: -8,523 For further information, refer to the FLEXlm End User Manual, available at "www.macrovision.com (http://www.macrovision.com/)".
Error: Current license file does not support the EPM7128SLC84-7 device
can somebody tell me whats going on is altera is telling somthing and giving something else !!!!!!!!!!!???????
are you using Quartus II 10.0 Web Edition? it looks like Quartus is still pointed at a license file, C:\altera\91\quartus\license.dat. for web edition you shouldn't need a license unless you have purchased ip.
go to Tools > License Setup and remove the path to that license, and you should be able to compile
