17235 Discussions
Quartus Prime Lite no Slew Rate Setting?
Wavelength
I am working on a design in Quartus Prime Lite for a MAX-V CPLD.
I have everything compiling and spent a couple hours setting the IO types, current and pin#s but I don't see anywhere to the set the Slew Rate that is mentioned in the data sheets, handbook and other documents in the Lite software.
I see video's from college classes showing it but I don't see or able to enable that option in the Pin Planner.
Do I really need to spend $3000 to get that option?
Gordon
Wavelength
Ok, right clicking, then customize, then add Slow Slew Rate.
Gordon
sstrell
You can use the Assignment Editor or right-click in the All Pins list in Pin Planner and select Customize Columns to display additional assignments.
Wavelength
Thanks for the quick response!
But there is no slew rate option in either one the Pin Planner or Assignment Editor. If I right click in the pin planner all the options are enabled and there is no options for Slew Rate in the Lite version.
Gordon
sstrell
So in Customize Columns, there's no option for slew rate?
Wavelength
Gordon
