17241 Discussions
Quartus Prime Lite simulation error
Developer_123
I have installed Quartus Prime Lite in my system using the .tar file. Both questa_fe and questa_fse folders are available after installation. However, when I try to simulate my design an error is displayed as given below.
**** Running the ModelSim simulation ****
C:/intelFPGA_lite/21.1/questa_fse/win64/vsim -c -do firstexample.do
Unable to checkout a license. Make sure your license file environment variable (e.g., LM_LICENSE_FILE)
is set correctly and then run 'lmutil lmdiag' to diagnose the problem.
Unable to checkout a license. Vsim is closing.
** Error: Invalid license environment. Application closing.
Error.
From what I read I understood there is no need of license for Quartus Prime Lite but Questasim FPGA starter requires a free license. Will the license be downloaded along with the .tar file or do I have to download it separately? I f I have to down it separately, could you please show me the path to download it. I have registered in Self Service License Centre but cannot find the license downloading options.
Also, when I checked my folders both questa_fe and questa_fse have a LICENSE file and I have set the LM_LICENSE_PATH variable pointing to these files.. But the error still exists. I have used the default settings in Quartus Prime Lite for simulation. (Should I set the path for Questasim simulator like a third party EDA tool?)
Any help regarding this would be appreciated.
Art_the_Dart
Is there an answer for this question? I'm having the same issue with Quartus Prime Lite asking for a license file when documentation says it's not required.
Roberto07
This video shows you how to obtain the license.dat file needed. It Is sent to you by email after your request, and It depends on your PC Mac address:
https://youtu.be/F6FvXga4f1A
