17268 Discussions
Quartus Pro 22.2: enum logic vs logic : Error(16983): arrays have different elements
alexislms
Valued Contributor I
module tb;
  enum logic [7:0] {A, B, C} fsm [4];
  logic [7:0] state [4];
  assign state = fsm;
endmodule
Never had an issue with Vivado and never had an issue with Modelsim: https://www.edaplayground.com/x/S3Va
With Quartus Pro 22.2, I get Error(16983): arrays have different elements
I believe this should be allowed by the specs.
RichardTanSY_Altera
Yes, there is a plan to fix this but it may takes time and I do not have the exact detail on when it will be fix. As this is subject to change.
RichardTanSY_Altera
Let me check this with the engineering team.
RichardTanSY_Altera
Fyi, the engineering team is working on this.
Please do expect that any work involves engineering may takes some time depending on the issue complexity.
Richard Tan
RichardTanSY_Altera
May I know are these code for testbench usage?
alexislms
Not only, we mainly use it in our synthesizable code.
RichardTanSY_Altera
A workaround suggested by the engineering team is to change RTL a little bit.
By changing the assignment of unpacked type to bit by bit instead of complete.
for the given design example
module tb;
 assign state[0] = fsm[0];
 assign state[1] = fsm[1];
assign state[2] = fsm[2];
 assign state[3] = fsm[3];
//assign state = fsm;
endmodule
The engineering team will check with the tool vendor on fixing this issue.
alexislms
@RichardTanSY_Altera  Thank you for the follow-up.
The workaround defeats the purpose of these data types, we will wait for the fix.
RichardTanSY_Altera
Do you able to escape the error based on the last email that I sent?
alexislms
Can we expect this to be fixed in a new release?
RichardTanSY_Altera
alexislms
Thank you, please feel free to close the case.
RichardTanSY_Altera
With that, I will now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
Richard Tan
p/s: If any answer from the community or Intel Support are helpful, please feel free to give best answer or rate 9/10 survey.
