17254 Discussions
Quartus SE closes when opening a project designed with Web Edition
Hi everyone,
I have problem with Quartus II Subscription edition V.12. In the past I used the Web Edition V.11 to develop systems on a Cyclon III FPGA. Now I want to use the Subscription Edition to open these projects. When I first tried to open the project I hadnt installed the Cyclone Device Support, but I was able to open the project. Since I installed the Cyclone Device Support, everytime I try to open an old project, Qartus immediately closes without an error message! Did anoyone else encounter this problem and has solution?
Thank you very much
Felix
Did you try after deleting the db directories, or with an archived project?
I just copy the old project to a new location and opende the project-file. Is that the problem?
I tried it again after deleting the db folder, but the same keeps happening!
