17256 Обсуждение
Quartus - assembler not generating sof file
Почетный участник II
18 160Просмотр.
By default Quartus assembler generates sof file, however, it's no more in our case. Any particular settings that is causing this ? The Quartus I am using is not an evaluation copy.
0 баллов
26 Ответы
10 074Просмотр.
Go to Assignments -> Settings
Compilation Process settings
Make sure "Run Assembler during compilation" is ticked.
10 074Просмотр.
--- Quote Start ---
--- Quote End ---
I can confirm this is ticked and Assembler does run in the compilation process, however, no sof file is generated.
10 074Просмотр.
Can you check the assembler report? There should be a table of generated files, and maybe a warning in the messages if no .sof file was generated.
10 074Просмотр.
To generate a new sof file thanks to start assembler in quartus processing menu,
do I have to open before a specific file from my project ?
because when I open my project .qpf and start assembler it doesn't work
Error: Run Fitter (quartus_fit) before Assembler (quartus_asm)
Error: Quartus II Assembler was unsuccessful. 1 error, 0 warnings
10 074Просмотр.
There was a problem with the fitter - what was the error?
10 074Просмотр.
--- Quote Start ---
--- Quote End ---
Try deleting the folders "db" and "incremental_db", before compiling the project.
Sometimes that helps if Quartus is doing weird things.
10 078Просмотр.
I did what you said vhdl_world and the problem with run fitter disappeared, so it's ok.
But I have the Error: Run Analysis and Synthesis (quartus_map) with top-level entity name "top_fpga_opg_master" before running the Assembler (quartus_asm)
I don't know where is the problem ?
Do I have to settle something ?
10 078Просмотр.
--- Quote Start ---
--- Quote End ---
So, why don't you do that (Run Analysis and Synthesis with "top_fpga_opg_master")?
Is your top module selected correctly? Otherwise go to "Project Navigator" window > Files > Right click on the correct file and "Set as Top-Level Entity".
good luck!
10 078Просмотр.
--- Quote Start ---
--- Quote End ---
Either the fitter didn't run successfully in the previous attempt or the data base files get corrupted somehow....Please delete the db and incremental db folder and rerun the whole process till fitter.
10 078Просмотр.
Julien_92, are you starting the compilation with a script or with Gui (Quartus II)?
Is the line "Analysis and Synthesis" green, as in the picture below/attachment?
Are there any other Error messages?
10 078Просмотр.
Thank you assembler worked but I don't have my new sof file in my Quartus project ? I still have my old one. I wanted to know why did we have to delete db and incremental db to run fitter ?
10 078Просмотр.
Warning: Can't generate programming files for your current project because you do not have a valid license for the following IP core or cores.
Like AlphaKh the quartus I use is not an evaluation copy so where is the problem ?
10 078Просмотр.
Does anyone know how to solve this problem please ?
10 078Просмотр.
Hi Julien,
Can you provide more details like:
1) What Quartus version and device you're using?
2) Are there any error messages that pop up or everything went smoothly but it just didnt generate any .SOF file?
10 078Просмотр.
--- Quote Start ---
--- Quote End ---
What licence do you have? the error says you dont have a licence for the specific IP cores - some have to be purchased separately
Also, web edition only covers a few devices.
10 078Просмотр.
I use Quartus II, the only problem is when I want to generate a .sof otherwise I don't have others warnings.
Warning : Can't generate programming files for your current project because you do not have a valid license for the following IP core or cores
10 078Просмотр.
The warning tells you the problem - you dont have a valid licence.
10 078Просмотр.
It's a stupid question but can I download another Quartus II software free without having problem
with the license when I want to generate a .sof file ?
And if it's the case do you have a link to download this one ?
Thank you
10 078Просмотр.
with the licence when I want to generate a .sof file ?
Thank you
9 197Просмотр.
Afaik, anyone can download the software. But unless you have the correct licence, you cannot generate sof file.
Ответить
