- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Subscrever fonte RSS
- Destacar
- Imprimir
By default Quartus assembler generates sof file, however, it's no more in our case. Any particular settings that is causing this ? The Quartus I am using is not an evaluation copy. Thanks,Link copiado
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Go to Assignments -> Settings
Compilation Process settings Make sure "Run Assembler during compilation" is ticked.- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
--- Quote Start --- Go to Assignments -> Settings Compilation Process settings Make sure "Run Assembler during compilation" is ticked. --- Quote End --- I can confirm this is ticked and Assembler does run in the compilation process, however, no sof file is generated.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Can you check the assembler report? There should be a table of generated files, and maybe a warning in the messages if no .sof file was generated.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
To generate a new sof file thanks to start assembler in quartus processing menu,
do I have to open before a specific file from my project ? because when I open my project .qpf and start assembler it doesn't work Error: Run Fitter (quartus_fit) before Assembler (quartus_asm) Error: Quartus II Assembler was unsuccessful. 1 error, 0 warnings- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
There was a problem with the fitter - what was the error?
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
--- Quote Start --- To generate a new sof file thanks to start assembler in quartus processing menu, do I have to open before a specific file from my project ? because when I open my project .qpf and start assembler it doesn't work Error: Run Fitter (quartus_fit) before Assembler (quartus_asm) Error: Quartus II Assembler was unsuccessful. 1 error, 0 warnings --- Quote End --- Try deleting the folders "db" and "incremental_db", before compiling the project. Sometimes that helps if Quartus is doing weird things.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
I did what you said vhdl_world and the problem with run fitter disappeared, so it's ok.
But I have the Error: Run Analysis and Synthesis (quartus_map) with top-level entity name "top_fpga_opg_master" before running the Assembler (quartus_asm) I don't know where is the problem ? Do I have to settle something ?- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
--- Quote Start --- I did what you said vhdl_world and the problem with run fitter disappeared, so it's ok. But I have the Error: Run Analysis and Synthesis (quartus_map) with top-level entity name "top_fpga_opg_master" before running the Assembler (quartus_asm) I don't know where is the problem ? Do I have to settle something ? --- Quote End --- So, why don't you do that (Run Analysis and Synthesis with "top_fpga_opg_master")? Is your top module selected correctly? Otherwise go to "Project Navigator" window > Files > Right click on the correct file and "Set as Top-Level Entity". good luck!
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
--- Quote Start --- To generate a new sof file thanks to start assembler in quartus processing menu, do I have to open before a specific file from my project ? because when I open my project .qpf and start assembler it doesn't work Error: Run Fitter (quartus_fit) before Assembler (quartus_asm) Error: Quartus II Assembler was unsuccessful. 1 error, 0 warnings --- Quote End --- Either the fitter didn't run successfully in the previous attempt or the data base files get corrupted somehow....Please delete the db and incremental db folder and rerun the whole process till fitter.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Thank you assembler worked but I don't have my new sof file in my Quartus project ? I still have my old one. I wanted to know why did we have to delete db and incremental db to run fitter ?
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Warning: Can't generate programming files for your current project because you do not have a valid license for the following IP core or cores.
Like AlphaKh the quartus I use is not an evaluation copy so where is the problem ?- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Does anyone know how to solve this problem please ?
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hi Julien,
Can you provide more details like: 1) What Quartus version and device you're using? 2) Are there any error messages that pop up or everything went smoothly but it just didnt generate any .SOF file?- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
--- Quote Start --- Does anyone know how to solve this problem please ? --- Quote End --- What licence do you have? the error says you dont have a licence for the specific IP cores - some have to be purchased separately Also, web edition only covers a few devices.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
The warning tells you the problem - you dont have a valid licence.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
It's a stupid question but can I download another Quartus II software free without having problem
with the license when I want to generate a .sof file ? And if it's the case do you have a link to download this one ? Thank you- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
with the licence when I want to generate a .sof file ? And if it's the case do you have a link to download this one ? Thank you- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Afaik, anyone can download the software. But unless you have the correct licence, you cannot generate sof file.
- Marcar tópico como novo
- Marcar tópico como lido
- Marcador
- Subscrever
