17255 讨论
Quartus_cdb (17.1/18.0) crashes while generating VQM for StratixV for a simple adder
名誉分销商 II
1,587 次查看
Hi All,
I am using Quartus17.1 as well as Quartus 18.0
quartus_cdb crashes with following error only when StratixV family is used:
*** Fatal Error: Segment Violation at (nil)
Module: quartus_cdb
Stack Trace:
0xbbd90: DEV_DEVICE::get_pad_info() const (ddb_dev)
End-trace
The verilog file, Add_24Ux24U_24U_4.v :# ##########################
module Add_24Ux24U_24U_4 (
in2,
in1,
out1
input [23:0] in2,
in1;
output [23:0] out1;
wire [23:0] asc001;
assign asc001 =
+(in2)
+(in1);
assign out1 = asc001;
endmodule# ########################
The tcl file (syn.tcl):# ########################
load_package flow
load_package report
load_package sdc
set module "Add_24Ux24U_24U_4"
proc syn { module family verilogInput} {
set proj [project_new -overwrite $module]
set_global_assignment -name FAMILY $family
set_global_assignment -name DEVICE Auto
set_global_assignment -name VERILOG_FILE ${module}.v
set_global_assignment -name NUM_PARALLEL_PROCESSORS 2
set_instance_assignment -name VIRTUAL_PIN ON -to in*
set_instance_assignment -name VIRTUAL_PIN ON -to out*
set_instance_assignment -name PARTITION_HIERARCHY root_partition -to | -section_id Top
execute_module -tool map
execute_module -tool fit
execute_module -tool cdb -args "--vqm=${module}.vqm"
project_close
syn $module "StratixV" $module# ########################
Command used to run
> quartus_sta -t syn.tcl
Please let me know any solution to this issue.
Srinivasa
0 项奖励
1 回复
名誉分销商 II
752 次查看
Contents of cr_ie_info.json
"system" : {
"platform" : "linux64",
"os_name" : "Red Hat",
"os_version" : ""
"error" : {
"executable" : "quartus_cdb",
"comment" : "not_applicable",
"error_message" : "Segment Violation at (nil)",
"source_file" : "unknown",
"line" : "0",
"stack_trace" : "\t0x7f387c125d60: ddb_dev + 0xbad60 (_ZNK10DEV_DEVICE12get_pad_infoEv + 0)\n",
"subsystem" : "unknown"
"quartus" : {
"quartus_bits" : "64",
"version" : "15.1.0",
"build" : "185",
"edition" : "Standard Edition"
0 项奖励
回复
