17263 Discussions
Compile error whilel using Quartus Prime
I am getting the following compile errors while compiling a project in quartus prime, as follows:
Error (275029): Incorrect connector style at port "dataa[7..0]" for symbol "inst" of type mult
Error (275029): Incorrect connector style at port "datab[7..0]" for symbol "inst" of type mult
Error (12153): Can't elaborate top-level user hierarchy
https://alteraforum.com/forum/attachment.php?attachmentid=15391&stc=1 I tried changing to bus line, but it dint work. I also tried using a diagonal bus tool while drawing. That dint work either.
Please help.
You've got a single bit wire connecting from the datab input to what looks like the clock input on the ram instance. There's also a wire shorting between the clock and dataa inputs of mult.
They're on the left edge of the mult instance so they are hard to see.
Thanks sstrell. I will try it out and see.
Hi, I corrected the design entry. I am finally seeing the following errors, which I have been unable to get rid of:
1. Incorrect connector style at port "dtaa[7..0]" for symbol "inst" of type mult
2. Can't elaborate top-level user hierarchy
Please help.:(. Modified schematic attached.
You can take a look at the attached project, I've created a almost identical design setup and have got it to compile successfully. The device used is different , while the LPM blocks used are almost the same with minor variations. You can use this as a reference.
You still have multiple shorts. Delete all the wires until you don't see any crosses or rounds and reconnect everything.
--- Quote Start ---
--- Quote End ---
Thank you Daixiewen. I tried doing that but a round still appears. I used a diagonal bus line to go from the first data(0..7) of mult to input vcc by clicking on one end and dragging till it meets the other end. A dot then appears. How do I get rid of it or draw so that it doesnt appear? Thanks in advance!
Delete and re-add components or drag components away from the shorts and delete them. Or drag a selection around the shorts to highlight them and delete.
