17255 Discussions
modelsim does not generate clock signal
I am trying to use testbenches in a big project. Quartus created tb itself and I just added a few lines within this testmodule:
initial begin
clk_clk = 0;
end
always# 10 clk_clk = ~clk_clk
Then by using RTL simulation I opened modelsim which added all wires of the project correctly but it is not simple generate clock
pic related
1) I did not find any explanation about grey lines. Why it even Pu0 (pull down?)
2) What did i wrong? I tried to follow altera RTL simulation guide
Looking forward any help :c i am very new to Quartus
It seems like Modelsim dont see my "always" blocks in testbench at all. Anything i write is not show up during RTL simulation
Did you set the testbench as the top level?
--- Quote Start ---
initial begin
clk_clk = 0;
end
--- Quote End ---
Let me know,
1. Are you able to compile Design & Testbench successfully?
2. All Inputs/Outputs are declared & initialized properly or not(declaration of clk_clk should be reg)?
3. can you provide code?
Let me know if this has helped resolve the issue you are facing or if you need any further assistance.
Best Regards
Vikas Jathar
(This message was posted on behalf of Intel Corporation)
Meaning did you instantiate your design under test in this testbench?
Thank you for all replies!
Well. Firtsly I created Testbench skeleton by Processing -> Start -> Test bench Writer
Then i added its link in Assingments -> Settings -> Simulation -> Native link settings
I modified TB with a few lines for modelsim to generate clock signal (just to try how it works)
But it is not work, even if i try to assing anything to 1'b1 or whatever.
Please guide how it supposed to work :c
clk_clk generated as reg
Replace sysclk by sysclk_period
It`s simple just provide input stimulus for example as follows & simulate,
always @(posedge SYSCLK_PERIOD) begin # 5 reset_reset_n = 1; # 50 reset_reset_n = 0; # 100 reset_reset_n = 1; # 25 reset_reset_n = 0; # 55 reset_reset_n = 1; end
find the attachment for screenshot.
Best Regards
Vikas Jathar
I replaced but still getting those strange pictures. I am sorry, but clock_period is a parameter (constant) how you made it posedge? Could you please provide me with your testbench file?
Thank you for your attention!
Yes, It should be "clk_clk".
Refer attached testbench file & run for more time like "run 50 ms".
Best Regards
Vikas Jathar
Nothing helps me :c
Maybe smth broken in Native link connetion. But when I intentionally made mistake in .vt file, Modelsim reported me about it so it sees and updates it during RTL simulation.
You seemed to simulate this project without Quartus, how?
I created own simple design file relative to the .vt file, refer the attached files & try yourself with fresh new project in Quartus tool.
Best Regards
Vikas Jathar
RTL simulation finally works! I used your guide and this helps!
Now i see it all the matter of names. I've used the name of TB file in native link settings, not the name, which Quartus gave to TB module.
Thank you a lot!
