17255 Discussions
Error (10759) when compile boardtest.cl kernel
when i run to compile boardtest.cl kernel, have the bellow error : error (10759) the verilog hdl error at boardtest_system.v :object kclk_finish declared in a list of port decralation cannot be redeclared within the module body file: e:/intelFPGA/17.1/hld/board/terasic/de1soc/example/boardtest/bin/boardtest/system/systhesis/submodule/boardtest_system.v line 488
did that file generate automatically?why still this error
Please attach the "quartus_sh_compile.log" file.
the quartus_sh_compile file attached ,please check...
--- Quote Start ---
Info (125068): Revision "top" was previously opened in Quartus II software version 16.0.2. Created Quartus Prime Default Settings File E:/intelFPGA/17.1/hld/board/terasic/de1soc/examples/boardtest/bin/boardtest/top_assignment_defaults.qdf, which contains the default assignment setting information from Quartus II software version 16.0.2.
--- Quote End ---
It seems the BSP you are using is not compatible with your version of Quartus. Check your board manufacturer's instructions as to which version of Quartus you should be using.
yes,i'm using quartus 17.1version while the BSP version of de1soc board is 16.0. but the de1-soc opencl user manual file don't write that bsp only install under quartus v16.0,so i'm not sure that error was caused by different version...
You can install Quartus 16.0.2 alongside with the version you have now and try to see if it works. If it still didn't, I recommend contacting Terasic's support.
