17254 Discussions
Quartus program not working, always in reses state?
popoff_1
Hi, I am struggling with my Quartus program. I have programmed a 7 segment calculator with four arithmetic operations: +-/* But when I insert a number with the switches, the 7 segment display does not light up. It always lightning up the same numbers(zeros), picture.
I have uploaded the code on my Altera DE-115 Board. I think the program works fine because all 7 segments lighting up correct, see picture. But I think its always in reset state. Does anybody know if it is possible that the program could be always in reset state and therefore i can not insert the numbers? Maybe I can upload here also my code, so someone could understand this better? Thanks for any help
sstrell
Yes, post some code.  No way to figure this out without seeing how you are creating the design.
popoff_1
Ok. Attached is my project, I have exporte as .qar file. I am very new in fpga and I would be happy for any help.
Maybe you or someone found an error.
paveetirrasrie_Intel
Just wanted to check with you, is your concern has been addressed?
If yes, kindly do let me know.
Thank You
We do not receive any response from you to the previous question that I have provided. This thread will be transitioned to community support.
If you have a new question, feel free to open a new thread to get the support from Intel experts.
Otherwise, the community users will continue to help you on this thread.
Thank you.
