17255 Discussions
Quartus "Launch Simulation Library Compiler" Errors
PSchl7
Hello
We are using "Quartus Prime Pro Edition" Version 23.2.0 Build 94 06/14/2023 SC Pro Edition.
We are trying to compile simulation libraries for Questasim 2023.1 for VHDL under "Quartus> Tools> Launch Simulation Library Compiler"
Unfortunately we get compile errors (see attached log).
Do you have us an advice for us of how to fix this issue?
Regards, Peter
RichardTanSY_Altera
Does the same error occur with Verilog option?
Do you also see the same error with the latest Quartus Pro version 24.1?
Are you using the Siemen Questasim or the Questa Intel FPGA Edition?
Questa Intel FPGA Edition seems to works fine.
Richard Tan
PSchl7
Hello Richard
Many thanks for your answer.
I did rerun the compiler with the Verilog option on and did use Siemens Questasim. It then passes without any errors.
Guess this is the way we have to use the "Simulation Library Compiler" in future.
Peter
RichardTanSY_Altera
Great to hear that. I'm pleased to know that your issue has been addressed.
Now, I will transitioning this thread to community support. If you have any further questions or concerns, please don't hesitate to reach out. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support.
The community users will be able to help you on your follow-up questions.
Thank you and have a great day!
Richard Tan
