17253 Discussions
Quartus synthesis constrain
In my project, the following code was to delay the data, I want to use the logic elements to implement in fpga, but the Quartus automatically use altshift_taps to implement which will cost one M9K.
Does there any constrains to constrain it using logic elements?
FPGA: EP3C40
QUARTUS II 8.1
-- delay the input data
pes_ua_array(0) <= pes_ua;
pes_ua_fs_array(0) <= pes_fs_ua;
pes_ua_delay:
for i in 1 to 13 generate
process(rst,clk)
begin
if (rst = '1') then
pes_ua_array(i) <= (others=>'0');
pes_ua_fs_array(i) <= '0';
elsif (clk'event and clk = '1') then
if (pes_v_ua = '1') then
pes_ua_array(i) <= pes_ua_array(i-1);
pes_ua_fs_array(i) <= pes_ua_fs_array(i-1);
end if;
end if;
end process;
end generate;
This might be helpful
http://quartushelp.altera.com/10.0/mergedprojects/hdl/vhdl/vhdl_file_dir_attribute.htm (http://quartushelp.altera.com/10.0/mergedprojects/hdl/vhdl/vhdl_file_dir_attribute.htm
As an example it shows the use of the AUTO_SHIFT_REGISTER_RECOGNITION attribute. Which it looks like you'll need to set to OFF
Hope this helps
Vern
Hi Vern,
Thank you very much!
Synthesis Attribute is what I need.
HXD
