17252 Discussions
Questa Intel Starter - How to get signal to display as a waveform in the Wave window
DukeCityWildcat
Can anyone tell me how I can get my "sum" signals to display as a waveform rather than a sequence of integer blocks? I attached the Wave window so you can see what I am talking about. I also attached the definition of the "sum" signal. I know it can be done, because I saw someone else on YouTube do it with similar code ( https://www.youtube.com/watch?v=1YnyNAxaJIg&list=PLGzeDuLmmxDrT1anK6PfgURjwVbwevuLV&index=5&ab_channel=MarcoWinzker ). I haven't got a response from him yet, so I thought I would try this message board.
Thanks for your help!
FvM
The question isn't completely clear. Are you referring to displaying an integer signal as a waveform curve? That's done by selecting Format->Analog in the wave viewer.
sstrell
You have sum as an integer so that's a 32-bit signal.  You would need to add the 32 individual signals to the wave window or there may be an option when you right-click sum in the Wave window.
FvM
DukeCityWildcat
Thanks, Format->Analog did the trick. Setting a good min and max value and selecting "Clamp waveform within row" gave me exactly what I was looking for!
Nurina
I can see that your question has been addressed, I now transition this thread to community support. If you have a new question, please login to https://supporttickets.intel.com , view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
p/s: If any answer from community or Intel support are helpful, please feel free to mark as solution, give Kudos and rate 4/5 survey
Nurina
