17268 Discussions
Questa Naivelink Error
HKubota
After this process
Re: Error while trying to run Questa simulator - Intel Communities
I have new following Error message.
Please tell me how to do no error.
Best regard
Info: Starting NativeLink simulation with Questa Intel FPGA software
Sourced NativeLink script c:/intelfpga_lite/22.1std/quartus/common/tcl/internal/nativelink/modelsim.tcl
invalid bareword "file"
in expression "file isdirectory $questa_f...";
should be "$file" or "{file}" or "file(...)" or ...
Error: NativeLink simulation flow was NOT successful
================The following additional information is provided to help identify the cause of error while running nativelink scripts=================
Nativelink TCL script failed with errorCode: TCL PARSE EXPR BAREWORD
Nativelink TCL script failed with errorInfo: invalid bareword "file"
(parsing expression "file isdirectory $ques...")
invoked from within
"if {file isdirectory $questa_fe_directory} {
set questa_installation $questa_fe_directory
set found_a_questa_installation 1
} else {
(procedure "find_a_questa_oem_installation" line 16)
invoked from within
"find_a_questa_oem_installation questa_installation"
invoked from within
"if [ catch { set install_path_from_registry [registry get "HKEY_LOCAL_MACHINE\\SOFTWARE\\Wow6432Node\\Intel Corporation\\Quartus Prime\\$quartus_versi..."
invoked from within
"if [ catch { set install_path_from_registry [registry get "HKEY_LOCAL_MACHINE\\SOFTWARE\\Intel Corporation\\Quartus Prime\\$quartus_version" "Questa I..."
(procedure "resolve_tool_path" line 102)
invoked from within
"resolve_tool_path "sim" "vsim" $args_hash(qsf_sim_tool)"
(procedure "launch_sim" line 29)
invoked from within
"launch_sim launch_args_hash"
("eval" body line 1)
invoked from within
"eval launch_sim launch_args_hash"
invoked from within
"if [ info exists ::errorCode ] {
set savedCode $::errorCode
set savedInfo $::errorInfo
error $result $..."
invoked from within
"if [catch {eval launch_sim launch_args_hash} result ] {
set status 1
set save..."
(procedure "run_sim" line 74)
invoked from within
"run_sim run_sim_args_hash"
invoked from within
error "$result" $savedInfo ..."
(procedure "run_eda_simulation_tool" line 334)
invoked from within
"run_eda_simulation_tool eda_opts_hash"
ShengN_Intel
I tested the nativelink without any problem check image below:
Assignments -> Settings -> EDA Tool Settings -> Simulation (image below):
Go to Tools -> Options -> EDA Tool Options -> Questa Intel FPGA and specify the paths:
<quartus_installdir>/questa_fe/bin (Linux)
<quartus_installdir>\questa_fe\win64 (Windows)
Make sure using compatible Questa FPGA Edition. And also proper license setup check this link https://www.intel.com/content/www/us/en/docs/programmable/683472/22-4/and-software-license.html
PC Operating System:
Edition Windows 11 Enterprise
Version 21H2
Installed on ‎12/‎13/‎2022
OS build 22000.1455
Experience Windows Feature Experience Pack 1000.22000.1455.0
Sheng
p/s: If any answer from the community or Intel Support are helpful, please feel free to give best answer or rate 4/5 survey.
ShengN_Intel
Do you have any further concern or update on this thread?
Sheng
