17267 Discussions
QuestaSim and CycloneV PLL:flat output
明张0002
Hello everyone,
I am tried to use the 'PLL_Reconfig_MNC.qar' example in AN661 on Altera PLL and Altera PLL Reconfig IP core of the Cyclone V,but I failed.When I simulating at Questasim,clock outputs from the pll stay at a value of '1' and it doesn't lock.
What makes it tricky is that I scan simulate the IP which contains the pll with a testbench and everthing works fine.But when this IP is placed in the example design it doesn't work.
What is puzzling is when I tried to use Arria 10 or Cyclone IV instead of Cyclone V in the example design,it works fine. ALL the above simulate are generated in Queartus Prime17.1 IP core,and then independently simulated with QuestaSim.Does  Queartus Prime17.1 not support pll reconfig of CycloneV?
RichardTanSY_Altera
Hi, please allow me some time to work on your request. I will get back to you as soon as possible.
