17266 Discussions
Question about FSM registered output logic
Suppose I've got the following code for registered output logic:
always 'at'(posedge clk)
begin
if (state == some_state) begin
output <= a;
end
end
I thought I would expect something like the following:
https://www.alteraforum.com/forum/attachment.php?attachmentid=6935
but instead waveform in modelsim was like:
https://www.alteraforum.com/forum/attachment.php?attachmentid=6936
I suspect the reason has something to do with using IF statement, but why? Any suggestion will be appreciated.
Depends on the exact timing of somestate. If it's set synchronously by clk, the first diagram would be correct.
--- Quote Start ---
--- Quote End ---
Transition of state is synchronous by clk, that's why I was confused by the waveform given in modelsim (the bottom figure).
Now to fix this (without knowing why) I raise a combinatorial flag at 'somestate', and 'output = a' will be set by this flag sequentially. So far so good. But is this making any difference to the original design after compile ? Thanks!
