17250 Discussions
/RESET signal in VHDL
Hi to all
In order to use VHDL Z80 and external VDP I need to build a /RESET signal.
I've tried this code :
--- Quote Start ---
library ieee;use ieee.std_logic_1164.all;
entity TB_RST is
port (
RESET_N : out std_logic
end TB_RST;
architecture BIDULE of TB_RST is
begin
RESET_N <= '0', '1' after 10 ns, '0' after 30 ns;
end BIDULE;
--- Quote End ---
The problem is that : when I compile with /RESET as input pin all is good but if I use this code the compiler show 0% like reset_n never change state
Of course, that is not synthesizable.
You need to use a clock and a counter to generate a reset.
I'm back with this.
I think it works , my led is on / off /on
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
entity reset is
Port (
clk_in : in STD_LOGIC;
reset_n: out STD_LOGIC
end reset;
architecture Behavioral of reset is
signal temporal: STD_LOGIC:='1';
signal cycle: integer range 0 to 2 := 0;
signal counter : integer range 0 to 10000000 := 0;
begin
frequency_divider: process (clk_in) begin
if rising_edge(clk_in) then
if (counter = 10000000) and (cycle /= 2) then
temporal <= NOT(temporal);
counter <= 0;
cycle <= cycle + 1;
else
counter <= counter + 1;
end if;
end if;
end process;
reset_n <= temporal;
end Behavioral;
Now I need to find good time for a valid /RESET signal.
