Ram and Rom
I have this Wrong Messages.:confused:
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all; entity BUS_VHDL is
port
CS_ROM_n : out std_logic;
CS_OUT_LED_n : out std_logic;
bus_en_n : in std_logic; <<wrong---- Error (12014): Net "gdfx_temp0", which fans out to "BUS_VHDL:inst4|bus_en_n", cannot be assigned more than one value ----
Addr_bus : in std_logic_vector(7 downto 0)
End entity;
architecture rtl of BUS_VHDL is
Begin
process(Addr_bus, bus_en_n)
begin
if bus_en_n = '0' then
if unsigned(addr_bus) > 0 AND unsigned(addr_bus) < 16 then -- ROM adress
CS_ROM_n <= '0';
else
CS_ROM_n <= '1';
end if;
if addr_bus = "00010000" then -- OUT_LED adress
CS_OUT_LED_n <= '0';
else
CS_OUT_LED_n <= '1';
end if;
else
CS_ROM_n <= '1';
end if;
end process;
end rtl;
It looks like the problem is from outside of this entity. You are trying to drive its bus_en_n input from two places simultaneously.
simultaneously how...? is it in this code..
You tell us by showing the code that instantiates this entity.
You've connected two things to bus_en_n. bus_en_n is an input to this entity, so the problem is not in this code.
