Read from a text file
I'm trying to read a text file with VHDL to generate some automatic input codes.
I made a project just to test this entity, but my output is always with value 'Z'.
my text file contains only one line and the line contains this
"11111111"
Observation : the cod.txt was created with QuartusII and is included to the project!
i think quartus can't open or read the file or something like that
thanks in advance
library std; library ieee; use std.textio.all; use ieee.std_logic_1164.all; entity readfile is port(clock : in std_logic; --output : out std_logic_vector(7 downto 0); output : out std_logic ); end readfile; architecture logic of readfile is --signal aux: std_logic_vector(7 downto 0); begin process(clock) variable inline:line; variable character_variable:character; variable end_of_line:boolean; file myfile:text is "cod.txt"; begin if(clock'event and clock = '1') then readline(myfile,inline); read(inline,character_variable,end_of_line); for i in 0 to 7 loop read(inline,character_variable,end_of_line); case character_variable is when '0' => output <= '0'; when '1' => output <= '1'; when others => output <= 'Z'; end case; end loop; --output <= aux; end if; end process; end logic;
Ohhhhhhhhhhhhhhhhh
so the problem is the Quartus Software...
the modelSim from altera can read it then?
--- Quote Start ---
--- Quote End ---
Read the above posts... everything has been said.
P.S.: The Atera edition has all basic ModelSim features.
Thanks eveyrone for this big help!
