17255 Discussions
Real time Counter in Kernel
I want to define a real time counter and print his result .
Can I define Real time clock "i" in kernel and print the result of counter?.
In Other hand, I thought that I define a counter "i" in my Kernel and I store My counter "i" in global memory and then I read buffer from Host.
My question : Does this counter "i" defined in kernel works under real time FPGA clock ?
If yes , How I can print the result of counter ? This code (below) doesn't work for me.
Kernel (
__global uint *restrict Y,
int Gid = get_global_id(0);
i=i+1;
Y[Gid]=i;
Thank you.
There is no clock in OpenCL and there is no guarantee that your accumulation will happen once every clock. You will not be able to get clock-accurate timing results in OpenCL. However, you can get very accurate timing results (but not clock-accurate) by using OpenCL's built-in profiler:
https://stackoverflow.com/questions/23550912/measuring-execution-time-of-opencl-kernels
