17255 Discusiones
Request for help in VHDL troubleshooting
Colaborador Distinguido II
3.406 Vistas
Hi all,
I am a new to programming of VHDL to FPGA.
Recently tried experimenting with a code from a book and during simulation, it was functioning perfectly.
However after i programmed into Altera Cyclone IV EP4CE chip, the chip is always stuck at the default state regardless of the input.
Was suspecting that the clock input is not configured properly thus i assigned the clock to Pin25 and yet it is not helping.
Hope anyone can lend a helping hand to help troubleshoot.:(:confused:
Thanks alot in advance.
The code:
LIBRARY IEEE;
USE IEEE.STD_LOGIC_1164.ALL;
USE IEEE.STD_LOGIC_ARITH.ALL;
USE IEEE.STD_LOGIC_UNSIGNED.ALL;
ENTITY Traincollision IS
PORT( reset, clock, sensor1, sensor2,
sensor3, sensor4 : IN STD_LOGIC;
switch1, switch2 : OUT STD_LOGIC;
track1, track2, track3 : OUT STD_LOGIC;
dirA, dirB : OUT STD_LOGIC_VECTOR( 1 DOWNTO 0 ));
END Traincollision;
ARCHITECTURE a OF Traincollision IS
TYPE STATE_TYPE IS ( ABout, Ain, Bin, Astop, Bstop );
SIGNAL state: STATE_TYPE;
SIGNAL sensor12, sensor13, sensor24 : STD_LOGIC_VECTOR(1 DOWNTO 0);
BEGIN
PROCESS ( reset, clock )
BEGIN
IF reset = '1' THEN
state <= ABout;
ELSIF clock'EVENT AND clock = '1' THEN
CASE state IS
WHEN ABout =>
CASE Sensor12 IS
WHEN "11" => state <= About;
WHEN "10"=> state <= Bin;
WHEN "01" => state <= Ain;
WHEN "00"=> state <= Ain;
WHEN OTHERS => state <= ABout;
END CASE;
WHEN Ain =>
CASE Sensor24 IS
WHEN "11" => state <= Ain;
WHEN "10" => state <= ABout;
WHEN "01" => state <= Bstop;
WHEN "00" => state <= ABout;
END CASE;
WHEN Bin =>
CASE Sensor13 IS
WHEN "11" => state <= Bin;
WHEN "01" => state <= Astop;
WHEN "00" => state <= About;
END CASE;
WHEN Astop =>
IF Sensor3 = '0' THEN
state <= Ain;
ELSE
state <= Astop;
END IF;
WHEN Bstop =>
IF Sensor4 = '0' THEN
state <= Bin;
ELSE
state <= Bstop;
END IF;
END CASE;
END IF;
END PROCESS;
sensor12 <= sensor1 & sensor2;
sensor13 <= sensor1 & sensor3;
sensor24 <= sensor2 & sensor4;
Track1 <='0';
WITH state SELECT
Track3 <= '1' WHEN ABout,
'1' WHEN Ain,
'1' WHEN Bin,
'1' WHEN Astop,
'1' WHEN Bstop;
WITH state SELECT
Track2 <= '0' WHEN ABout,
'0' WHEN Ain,
'1' WHEN Bin,
'1' WHEN Astop,
'0' WHEN Bstop;
WITH state SELECT
Switch1 <= '0' WHEN ABout,
'0' WHEN Ain,
'1' WHEN Bin,
'1' WHEN Astop,
'0' WHEN Bstop;
WITH state SELECT
Switch2 <= '0' WHEN ABout,
'0' WHEN Ain,
'1' WHEN Bin,
'1' WHEN Astop,
'0' WHEN Bstop;
WITH state SELECT
DirA <= "01" WHEN ABout,
"01" WHEN Ain,
"01" WHEN Bin,
"00" WHEN Astop,
"01" WHEN Bstop;
WITH state SELECT
DirB <= "01" WHEN ABout,
"01" WHEN Ain,
"01" WHEN Bin,
"01" WHEN Astop,
"00" WHEN Bstop;
END a;
0 kudos
20 Respuestas
2.341 Vistas
Have you written a testbench for this code - have you simulated it>?
2.341 Vistas
--- Quote Start ---
--- Quote End ---
Hi Tricky,
Thanks for the reply.
How do i go about writting a testbench for the code?
Read up a few website but still clueless about it.:confused:
And website that can help?
Greatly appreciate ur help.
2.341 Vistas
There are plenty of tutorial websites. A testbench is some VHDL code that stimulates your design under test. It doesnt have to be synthesisable and you can do plenty of "programming" like things. For example, to generate a clock, you can write:
signal clk : std_logic := '0'; .... clk <= not clk after 5 ns; -- 100 Mhz clock
2.341 Vistas
--- Quote Start ---
--- Quote End ---
Geezz..Thanks!
Having problem understanding the testbench thing.
What is the difference between a testbench and simulation with waveform?
2.341 Vistas
Assuming you're creating a waveform to drive a DUT (design under test), then your waveform IS your testbench.
You run your testbench and DUT in a simulator and you can veiw the waveform in the wave window in the normal way. You need to use a proper simulator (like modelsim) to do HDL simulation. The quartus simulator is not very powerful and only simulates the compiled netlist via waveforms which is very slow compared to simulating the HDL directly.
Another advantage of using HDL as the testbench is you can generate far more complex input stimulus, and output practically anything to text files.
2.341 Vistas
--- Quote Start ---
--- Quote End ---
Thanks for the explanation.
I did the waveform simulation in modelsim then and design work perfectly.
However the moment i programmed in and tried out with hardware,it only stay at the default state.:confused:
Tried for days troubleshooting but to no avail.
2.341 Vistas
First a small remarkUSE IEEE.STD_LOGIC_UNSIGNED.ALL;Try to avoid that non standard library as much as possible. There are unfortunately several VHDL books that still use it, but the recommended library for arithmetic is ieee.numeric_std.all. Logic_unsigned will cause you problems the day you will also want to use signed logic in the same architecture, and doesn't live well with numeric_std.
Now for you problem I'd definitely check the reset and clock signals first. Are you sure your reset signal is active high? Is your clock on the correct pin? You can use signaltap to record your reset signal, using "clock" as a clock. Then if you don't have a clock you'll get a warning/error from Signaltap, and if you do you will be able to check the polarity of the reset signal. If both look ok then you can begin and checking the other signals from your state machine.
2.341 Vistas
--- Quote Start ---
--- Quote End ---
Hi daixiwen,
Thanks for introducing the signaltap function to me..
Both u n tricky are a great help,learnt something from u guys!
2.341 Vistas
Hi Tricky and Daixiwen,
I have tried both the waveform simulation and the signaltap.
Noticed that the default state is 'ABout' and it is alway in default state even though i tried triggering the sensor 1 and sensor 2.
Rightfully when sensor 1 is a high then the state should have switch from ABout to Ain.
Yet both ABout and Ain are activated.
In this case, what will be the state that the chip is in?:confused:
2.341 Vistas
Your diagram shows that the reset signal is constant '1' - why?
2.341 Vistas
--- Quote Start ---
--- Quote End ---
Hi tricky, good observation..
I have set it to active '0' instead..
2.341 Vistas
Could you show us your new code? (put it between and tags to preserve formatting)
There seems to be some inconsistencies between the code and the signaltap screenshot.
Also you should start with a proper reset pulse before putting some signals on the sensors, to be sure you start in a correct state.
2.341 Vistas
Hi there, sorry for the late reply.
Was tied up with work.
Below is the code for the program.
I tried signaltap on it and upon toggling the sensor 1/2, i was expecting it to enter into Ain/Bin state. But yet it seem to only trigger at the first try after reset. The subsequent tries has no response. Can help advise?
Thanks alot!
LIBRARY IEEE; USE IEEE.STD_LOGIC_1164.ALL; USE IEEE.STD_LOGIC_ARITH.ALL; USE IEEE.NUMERIC_STD.all; ENTITY Tcontrol1 IS PORT( reset, clock, sensor1, sensor2, sensor3, sensor4 : IN STD_LOGIC; switch1, switch2, switch1a, switch2a : OUT STD_LOGIC; track1, track2, track3 : OUT STD_LOGIC; dirA, dirB : OUT STD_LOGIC_VECTOR( 1 DOWNTO 0 )); END Tcontrol1; ARCHITECTURE a OF Tcontrol1 IS TYPE STATE_TYPE IS ( ABout, Ain, Bin, Astop, Bstop ); SIGNAL state: STATE_TYPE; SIGNAL sensor12, sensor13, sensor24 : STD_LOGIC_VECTOR(1 DOWNTO 0); BEGIN PROCESS ( reset, clock ) BEGIN IF reset = '0' THEN state <= ABout; ELSIF clock'EVENT AND clock = '1' THEN CASE state IS WHEN ABout => CASE Sensor12 IS WHEN "11" => state <= About; WHEN "10"=> state <= Bin; WHEN "01" => state <= Ain; WHEN "00"=> state <= Ain; WHEN OTHERS => state <= ABout; END CASE; WHEN Ain => CASE Sensor24 IS WHEN "11" => state <= Ain; WHEN "10" => state <= ABout; WHEN "01" => state <= Bstop; WHEN "00" => state <= ABout; WHEN OTHERS => state <= ABout; END CASE; WHEN Bin => CASE Sensor13 IS WHEN "11" => state <= Bin; WHEN "10" => state <= ABout; WHEN "01" => state <= Astop; WHEN "00" => state <= About; WHEN OTHERS => state <= ABout; END CASE; WHEN Astop => IF Sensor3 = '0' THEN state <= Ain; ELSE state <= Astop; END IF; WHEN Bstop => IF Sensor4 = '0' THEN state <= Bin; ELSE state <= Bstop; END IF; END CASE; END IF; END PROCESS; sensor12 <= sensor1 & sensor2; sensor13 <= sensor1 & sensor3; sensor24 <= sensor2 & sensor4; Track2 <='0'; WITH state SELECT Track3 <= '0' WHEN ABout, '0' WHEN Ain, '0' WHEN Bin, '0' WHEN Astop, '1' WHEN Bstop; WITH state SELECT Track1 <= '0' WHEN ABout, '0' WHEN Ain, '0' WHEN Bin, '1' WHEN Astop, '0' WHEN Bstop; WITH state SELECT Switch1 <= '0' WHEN ABout, '0' WHEN Ain, '1' WHEN Bin, '1' WHEN Astop, '0' WHEN Bstop; WITH state SELECT Switch2 <= '0' WHEN ABout, '0' WHEN Ain, '1' WHEN Bin, '1' WHEN Astop, '0' WHEN Bstop; WITH state SELECT Switch1a <= '1' WHEN ABout, '1' WHEN Ain, '0' WHEN Bin, '0' WHEN Astop, '1' WHEN Bstop; WITH state SELECT Switch2a <= '1' WHEN ABout, '1' WHEN Ain, '0' WHEN Bin, '0' WHEN Astop, '1' WHEN Bstop; WITH state SELECT DirA <= "01" WHEN ABout, "01" WHEN Ain, "01" WHEN Bin, "00" WHEN Astop, "01" WHEN Bstop; WITH state SELECT DirB <= "01" WHEN ABout, "01" WHEN Ain, "01" WHEN Bin, "01" WHEN Astop, "00" WHEN Bstop; END a;
2.341 Vistas
have you got a testbench for this code, rather than trying to debug it on hardware (which takes much much longer)
2.341 Vistas
--- Quote Start ---
--- Quote End ---
Hi Tricky,
Is this considered testbench?
2.341 Vistas
it seems You should check sensor4 )
and
2.341 Vistas
--- Quote Start ---
and
--- Quote End ---
Hi Alex96,
Thanks for the pointers.
Mind sharing the concerns with sensor4?
2.341 Vistas
--- Quote Start ---
Hi Tricky,
--- Quote End ---
No - this is a waveform from a simulator. How are you producing the waveform?
2.341 Vistas
--- Quote Start ---
Thanks alot!
--- Quote End ---
Forgot to add on that the sensor circuitry are active low.
When they are triggered, they goes low.
2.288 Vistas
my Advice: after source will be compiled You should open RTLViewer and StateMachineViewer. Try to make analysis step-by-step. Then compare to your waveforms.
Responder
