17268 Discussions
Reversing a bus in SystemVerilog
AWilc1
Is there a way to reverse a bus in systemverilog?
I am trying to do:
genvar j;
generate
  for ( j=0 ; j < 256 ; j=j+1 ) begin
    out[j] <= in[256-j];
  end
endgenerate
But when I compile in ModelSim I get the errors:
** Error: (vlog-13069) near "[": syntax error, unexpected '['.
** Error: (vlog-13205) Syntax error found in the scope following 'out'. Is there a missing '::'?
I cannot see what is wrong here. Can anyone more familiar with SV see what is wrong?
dave_59
The problem is with the procedural assignment statement inside your generate loop. Assuming out is declared as a wire, you need to change it to
for (genvar j=0j<256;j++) assign out[j] = in[256-j];
But there us a much simpler way of writing this without a loop using the streaming operator
assign out = {<<{in}};
dave_59
