17257 Discussions
SOPC Builder v 10.1 Custom Component Problem
I have design my custom component. I have used both Avalon Slave and Avalon Master Interface. TCL file works for SOPC Builder v 9.1. However in v10.1 I am getting following warnings
(1) cpu_0 : Custom Instruction components can be edited through the component editor.
(2) cpu_0 : Disabling the assign CPUID control register value manually will not longer auto assigns unique control value. This options will always be turned on with default value set to 0.
Whenever I am connecting my Avalon Master Interface to any other Avalon Slave interface I am getting following warnings
(1)onchip_memory_0.s1 : dma_master(Custom Component Interface name) must be the only master because wait-request is missing.
I have used wait-request for both interface(Avalon Master and Avalon Slave) in my TCL file.
Please help me to remove this warnings.
Thanks in advance,
Krupesth
Why no replys? I'm getting these two warnings in v10.1, too.
Just double click on nios II cpu and you will not find these two warnings.
Kruepsh
Thank you very much.I have solved my problems with your tip.
