SUm of table
榮譽貢獻者 II
1,344 檢視
Please can you help me to write a Verilog code to calculate sum of table, I have a code that’s calculate with this manner.
generate
if(z == 1)
assign x = y[0];
else if (z == 2)
assign x = y[0] + y[1];
else if (z == 3)
assign x = y[0] +y[1] + y[2] ;
endgenerate
I need to let’s this code a generic using a boucle for to calculate sum of table using always block.
Thank you for your helps.
0 積分
2 回應
榮譽貢獻者 II
660 檢視
You don't say how wide your different signals are...
Assuming z is 2-bits wide, y 3-bits and x 1-bit:
reg x; always @ (*) case (z): 1 : x = y; 2 : x = y + y; 3 : x = y + y + y; endcase
This would also work if x & y are wider - but the same width as each other - and y an array.
You'll need to specify what happens to x in the case of z == 0.
Alex
榮譽貢獻者 II
660 檢視
Thank you very much. problem resolved with this solution.
回覆
