17268 Discussions
Setup time violation on HBMC clock Domain
SivaKona
Hi
I am getting Setup Time violations on HBMC clock Domain (500MHz) due to Long Routing paths.
Type : Setup 'hbm_top_inst|iopll_t|iopll_t_outclk0'
Slack : -1.109
TNS : -863.275
Corner: Slow 900mV 100C Model
Type : Setup 'hbm_bottom_inst|iopll_b|iopll_b_outclk0'
Slack : -1.021
TNS : -1141.048
Corner: 1 Slow vid1 100C Model
Could you please suggest a fix for this issue?
Siva Kona
RichardTanSY_Altera
Hi @SivaKona
May I know is the timing violation fail in our Intel IP or in the design?
Richard Tan
SivaKona
Hi Richard Tan,
Thanks for your reply!
Setup Time Violation is in Intel IP (Quartus generated HBM IP)
My idsid is snkona, Could you please share your idsid on Teams IM, so that I can share my VNC and the Build reports.
Siva Kona
Nurina
Hi Siva,
Following our discussion offline, problem has been root caused: HBMC IP & Quartus tool version mismatch
I’m glad that your problem has been solved. I now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
Nurina
P/S: If you like my comment, feel free to give Kudos. If my comment solved your problem, feel free to accept my comment as solution!
