17268 Discussions
Sharing of signals over different processes in modelsim not working as expected ?
JOHI
New Contributor II
For my test bench I have created a test bench with 3 separate processes.
The first process generates a clock.
The second process sets a signal " enable_clock" after reading a file with stimulae.
The third process waits for the flag "Enable_clock" to continue.
Although "Enable_clock" is set, the third process keeps on waiting on the line:
wait until enable_clock='1';
I verified this fact with breakpoints and with the "wave" display window: enable_clock is '1' but my process simulation is not moving forward.
Any help is appreciated.
Johi.
Tricky
New Contributor II
  1. That is because enable_clock is set to '1' after the first falling edge of the clock, and it remains at '1'.
The thrid process (main_data_gen) is waiting for enable_clock to toggle to '1' after the second clock. But it already at '1', and hence waits forever.
Wait until is triggered by a 'event on the sensitivy list (the signals you are waiting for).
the workaround is to do this:
if enable_clock /= '1' then wait until enable_clock = '1'; end if;
2. Now to comment on the code. Why are you manually waiting for edges on the clock? VHDL has the build in functions rising/falling_edge, so its usually much better to use those on the code, and is more readable. in addition, use loops to wait for a defined number of clocks:
for i in 1 to 10 loop -- wait for 10 clocks wait until rising_edge(clk); end loop;
or even better, in some tools package, define a procedure to wait for a specified number of clocks (its a pretty standard thing to want to do in any testbench:
procedure wait_for_clks( constant n : integer; signal clk : in std_logic ) is begin for i in 1 to n loop wait until rising_edge(clk); end loop; end procedure;   .......   process begin ...... wait_for_clks(10, clk); end process;
3. Next, if you want a process to halt, putting wait until 0=1; will wait forever, but its a fairly nonsense piece of code. Why not simply write "wait", as a single wait will wait forever
stim_proc : process begin ....do something wait_for_clks(10, clk); .. do something else wait; -- waits forever; end process;
4. For the PSD_data_table, why not set the values in an initialisation function, rather than assign them in a process?
JOHI
New Contributor II
Additional info:
- If I add a sensitivity list:
=> Error: A wait statement is illegal for a process with a sensitivity list. (Modelsim)
- If I remove sensitivity list:
=> Warning: Wait statement has no sensitivity list or time out clause; (Modelsim)
workaround / solution I found:
loop
         wait until CLOCK_50='1';
         wait until CLOCK_50='0';
          if ENABLE_CLOCK='1' then
             exit;
          end if;
end loop;
That my code cannot be compiled into hardware is obvious.
But since we are in simulation, i would assume that:
wait until ENABLE_CLOCK='1';
would do the same trick.
So I remain with the question what the proper way to share non clock signals over simulation processes in wait statements is?
Tricky
New Contributor II
JOHI
New Contributor II
Hello Tricky,
High appreciation for you analysis: Following Your comments:
1. AFIK, Vhdl  does not support "wait until" statements & parameters in the process sensitivity list, so solving the issue using an explicit process sensitivity list is was a dead end.
Your workaround for this property is very nice. I tried it; it works, this solution I would not have found myself. An alternative solution elaborating on and confirming your analysis: wait until (enable_clock and CLOCK_50) = '1' this also seems to work; "wait until" is evaluated each time "clock_50" changes.
2. Your solution is better. I have a C++ background, my old habbit is not completely dead yet for code that does not end up in an FPGA. I modified my code in line with your remarks. I also see speed improvements during simulation.
3. "Wait" was something I have been looking for but did not come across yet. Thanks.
4. The values in the .mif are generated by an .xls script. They will also be used in a second FPGA (DE2-115) I use it as a wave generator for the main FPGA (DE10-STD). I generate a complex wave form that will finally come out of a rotating wheel in front of a PbS sensor. I could generate a .vhd the same way I generate the .Mif file of course but if you try nothing you learn nothing.
Johi.
