17249 Discussions
Signal Tap Hierarchy Display (22.1std)
zhenge
Dear support,
I am new with Quartus 22.1std. Using SignalTap, I found very annoying having to click select inside the Hierarchy Display every time, I changed view or make changes to the trigger signal.
Signals are not available in the view window (Data, Setup) unless a module is selected by its checkbox inside the Hierarchy Display. The selection is gone, if view by clicking Data or Setup, delete/add any signal to trigger.
I have never seen this in previous versions of Quartus.
Please let me know if there is something I have to do to make all signals visible.
sstrell
Can you add a screenshot?  Not sure what checkboxes you are referring to.  After you add a signal to the Node List via the Node Finder, it should just be there in the list.
SyafieqS
By right that should not be happening.
After selecting the node in node finder, you can see the signal added in the signal tab.
SyafieqS
Let me know if there is any update from previous reply
zhenge
My example here, the first module (...TTP) got unselected automatically whenever I do anything on the data/trigger window.
sstrell
Oh, that hierarchy display is basically useless.  You don't need to do anything with it.  It just shows where Signal Tap lives in your Quartus project hierarchy.
zhenge
The trouble I have is I have to checkbox the entity within the Hierarchy Display to see signals (belongs to the entity).
sstrell
Yes, turning those off will filter what you've added to the node list.  Just leave them on.  Not sure what the issue is.
SyafieqS
SyafieqS
As we do not receive any response from you on the previous question/reply/answer that we have provided. Please login to https://supporttickets.intel.com/, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
p/s: If any answer from community or Intel support are helpful, please feel free to mark as solution, give Kudos and rate 5/5 survey
RHenr
Hello, did you find a solution ? I am facing the same issue, Hierarchy Display checkboxes unchecking with no reason ? (Quartus 23.1)
