17263 Discussions
Signal not assigned in init state
I am working on a simple state machine but for some reason the output value is not assigned correctly.
First it is supposed to go into state init and assign default values to my 4x8bit internal signals (key_int), then should go to state assign to assign and combine the internal signals into 1x32bit output signal (key). And that is where it fails. When I run my test bench it always shows that key="00000000000000000000000000000000". Although key_int(0..3) are set to x"61" during the init phase. I already placed a counter in both states so I don't get a timing problem. I also replace the array with 4x std_logic_vector signals and assiged those during init with the same result. Surpringly: when I assign key directly in init it takes it.
What am I doing wrong here?
Btw I am using Quartus II 15.0.0. if that makes any difference.
use ieee.std_logic_1164.all; use ieee.std_logic_unsigned.all; use ieee.numeric_std.all; entity buttonToKey is port( clk_50 : in std_logic; button : in std_logic_vector(5 downto 1); key: out std_logic_vector(31 downto 0) ); end buttonToKey; architecture behavior of buttonToKey is type state_type is ( init, evaluate, assign ); signal state : state_type := init; type my_array_type is array (0 to 3) of std_logic_vector(7 downto 0); signal key_int : my_array_type; signal index : integer := 0; signal count : unsigned( 18 downto 0 ) := ( others => '0' ); begin process( clk_50 ) begin if rising_edge( clk_50 ) then if state = init AND count = 100 then -- init and assign default char state <= assign; key_int( 3 ) <= x"61"; -- ASCII 'a' key_int( 2 ) <= x"61"; key_int( 1 ) <= x"61"; key_int( 0 ) <= x"61"; count <= ( others => '0' ); elsif state = evaluate then -- check which button is pressed if button = "10000" then -- button 5: increment ASCII character state <= assign; count <= ( others => '0' ); if unsigned( key_int( index ) ) = x"7A" then -- run circular between ASCII char 'a' and 'z' key_int( index ) <= x"61"; else key_int( index ) <= key_int( index ) + 1; end if; elsif button = "00001" then -- button 1: move to next position (start with 1) state <= evaluate; if index = 3 then index <= 0; -- overflow protection else index <= index + 1; end if; else state <= evaluate; end if; elsif state = assign AND count = 100 then -- assign any changed keys to output count <= ( others => '0' ); state <= evaluate; key <= key_int( 3 ) & key_int( 2 ) & key_int( 1 ) & key_int( 0 ); else count <= count + 1; end if; end if; end process; end behavior;
Testbench: -- i took most of the test code out since the first transition from init to assign is not working
BEGIN -- code that executes only once button <= "00000"; wait for 80 ns; button <= "00000"; wait for 80 ns; button <= "00000"; wait for 80 ns; button <= "00000"; wait for 80 ns; WAIT; END PROCESS init; always : PROCESS -- optional sensitivity list -- ( ) -- variable declarations BEGIN -- code executes for every event on sensitivity list WAIT; END PROCESS always; -- clock generation process process begin clk_50 <= '1'; wait for 10 ns; clk_50 <= '0'; wait for 10 ns; end process; END buttonToKey_arch;
Cheers and thanks!
Without the testbench, we cannot see whats going wrong.
I also note you're using buttons in the design. Have you properly synchronised and debounced them?
--- Quote Start ---
--- Quote End ---
Hello Tricky,
that is the actual test bench that is in use at the moment. It should start the state machine, go into theinit state with the 101st rising edge and assign key_int( 3..1 ) <= x"61"; . Then it should go to assign state after another 101 rising edges to combine the key_int(3..1) into the output key. The problem I am seeing is that key is always 0. So either it does not go into the init state, or it does not assign key_int or it never reaches the assign state. And I have trouble determining whether it is my code, something Quartus II specific or something completely different.
The reason why I wrote that "I took most of the code out" is that I reduced the test bench to what you see here to find the error. The test bench is pretty dumb at the moment, but should do a very simple thing..but it is not doing it.
--- Quote Start ---
--- Quote End ---
Yes, those are debounced in a separate module that feeds this buttontokey module. But this should not matter for the test bench, does it?
ninja edit: changed wording
Are you running the test for long enough? it will take 200 clocks for output "key" to be assigned to anything.
--- Quote Start ---
--- Quote End ---
I am running it for 4200 ns. The clock input is 50MHz or 20 ns periods. So 4200 ns should be sufficient.
This is the output of ModelSim:
http://www.alteraforum.com/forum/attachment.php?attachmentid=13398&stc=1
From your question I gather that the general code looks fine and should work?
Thank you.
Have you check that the counter and state are actually changing?
--- Quote Start ---
--- Quote End ---
Well, I have not checked the counter. I noticed however that when key is set in state init and not in state assign the value shows up in simulation. But when key is assigned in state init AND afterwards in state assign only the last value shows up in simulation..it is like it skipped the init state in that case.
Is there a way to monitor internal signals with ModelSim? I found this link which suggest it is possible (http://www.alteraforum.com/forum/showthread.php?t=47850&highlight=internal+signal+modelsim). But I could not find a description on how to do it.
If you're doing an RTL simulation, all internals can be put on the waveform. Click on the sim tab, select the module you want to look at then click on the objects tab - all internal signals should be listed.
Found it. It shows as "Not Logged" in my case. And as "No Data" when added to the wave form.
Yes, because it wasnt on the wave window when started, modelsim wont log it. Just restart the simulation and run it again. Easiest way is from modelsim console:
restart -f
run 1 us
It does look like you should see "key" change. It's not related to your question and just my two cents, but this is not a usual way to structure a FSM. Most people would use a case statement for each state. I'm not sure the tools will even recognize your code as a FSM (should still work though).
It's not clear what you mean by "I already placed a counter in both states so I don't get a timing problem." but the code would be much more clear if you put the counter in a separate process so that it is incremented and reset in one place instead of several.
counter_expired <= '1' when counter = 100 else '0'; counter_proc : process begin wait until CLK'EVENT and CLK = '1'; if(counter = 100 or reset_counter = '1') then counter <= (others => '0'); else counter <= counter + 1; end if; end process counter_proc;
then in the FSM:
case state is when init => if(counter_expired = '1') then ... end if; ...
If you are using VHDL 2008, you can access internal signal names in a testbench using the VHDL 2008 external names. Some examples here:
http://stackoverflow.com/questions/17287129/vhdl-alias-syntax (http://stackoverflow.com/questions/17287129/vhdl-alias-syntax
In fact, a simulation is sort of useless if you do not do so. Being VHDL, it is ten times more verbose than necessary, but it works.
Sorry for the unsought for suggestions; clearly had too much time on my hands today.
--- Quote Start ---
--- Quote End ---
I dont quite know what you're talking about, as simulation always has access to all internal signal names for the waveform. If you have to access internal signals in your testbench to act on them then there is probably something wrong with the design.
Btw - modelsim has signalspy to overcome internal access that you get with VHDL 2008, which has been around for a long long time
One way it works if a synchronous reset is implemented. If that is done the state machine starts in init as it should have done. This was not my doing btw. Credit goes to my TA who found that out.
Below the working code:
if rising_edge( clk_50 ) then if rst = '0' then state <= init; else if state = init AND count = 100 then -- init and assign default char state <= assign; key_int( 3 ) <= x"61"; -- ASCII 'a' key_int( 2 ) <= x"61"; key_int( 1 ) <= x"61"; key_int( 0 ) <= x"61"; count <= ( others => '0' ); -- key <= "11111111111111111111111111111111"; -- debug elsif state = evaluate then -- check which button is pressed if button = "10000" then -- button 5: increment ASCII character state <= assign; count <= ( others => '0' ); if unsigned( key_int( index ) ) = x"7A" then -- run circular between ASCII char 'a' and 'z' key_int( index ) <= x"61"; else key_int( index ) <= key_int( index ) + 1; end if; elsif button = "00001" then -- button 1: move to next position (start with 1) state <= evaluate; if index = 3 then index <= 0; -- overflow protection else index <= index + 1; end if; else state <= evaluate; end if; elsif state = assign AND count = 100 then -- assign any changed keys to output count <= ( others => '0' ); state <= evaluate; -- key <= key_int4 & key_int3 & key_int2 & key_int1; key <= key_int( 3 ) & key_int( 2 ) & key_int( 1 ) & key_int( 0 ); -- key <= "00000000001111111111000000000011"; -- debug else count <= count + 1; end if; end if;
--- Quote Start ---
--- Quote End ---
Yes you are right. This is not the standard state machine and if I look at the state machine template from the altera website - link (http://quartushelp.altera.com/15.0/mergedprojects/hdl/vhdl/vhdl_pro_state_machines.htm) or here - link (https://www.altera.com/support/support-resources/design-examples/design-software/vhdl/vhd-state-machine.html) it uses case state ..when=> structure but it does not say it is a nessecity.
In the quartus ii handbook volume 1 - link (https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&uact=8&sqi=2&ved=0ahukewjelyg5yu_sahujpiykhc1xd40qfggamaa&url=https%3a%2f%2fwww.altera.com%2fen_us%2fpdfs%2fliterature%2fhb%2fqts%2fqts-qps-5v1.pdf&usg=afqjcngnr1gq2_khvwqn9afvdjhqkzw35g&sig2=k1pkspsuefhkqwmvfcrmxq&bvm=bv.150729734,d.ewe) on page 12-50 it only says that to be recognized as a state machine I must use state type like this TYPE Tstate IS (state_0, state_1, state_2, state_3, state_4); SIGNAL state: Tstate; and also gives a few more suggestions.
Maybe that explains the strange behaviour? Maybe the case state ..when=> structure or a reset are necessary? Well, I don't know for sure now but since I got it working with above code I am satisfied for now!
Thanks @tricky and @corestar for your help and suggestions!
--- Quote Start ---
--- Quote End ---
Tricky, I'm probably not understanding what you are saying. You don't think it is useful for a testbench to access internal signals such as the state, count etc to see what is happening? Waveform windows are nice, but for complicated designs it is helpful to write code to verify results. I tend to agree it would be gross overkill in this case.
I rarely actually modify an internal signal, but it can be useful to simulate errors.
PuqmaStar,
I don't think it explains the strange behavior. It's not a matter of whether or not your way will work so much as efficiency. Your way entails multiple levels of logic. The tools are pretty smart and may be able to optimize it, but I would not depend on that (you could use the Netlist viewers to find out). With a case statement, it can jump to the proper block of hardware. A C/C++ switch statement is similar. The compiler creates a jump table whereas the equivalent if/else code would require evaluating each one until the proper case if found.
Also, tools like SignalTap have special ways of handling FSM if it recognizes it. You can tell it to insert the FSM and it will use the named states.
If your purpose in the count was to help meet timing, I would just get rid of it. Your simulation will be alot faster. For RTL simulation, timing does not matter and it actually hurts timing in any event. You've added more levels of logic.
It looks to me like you properly initialize the state variable and count. Resets are not a bad thing, but it seems like it should have worked before.
Not sure why your code caught my interest. Seems like it should work and probably something obvious.
PuqmaStar,
It just bothered me that I could not see what was wrong so I took a few minutes and ran it myself. Seems to work fine for me. I had to add
LIBRARY IEEE;
at the top of your code to get it to compile and changed count to 5 instead of 100. Perhaps you just missed that in the cut ans paste. Then did a simple test bench:
-- -- Simulation tool : ModelSim-Altera (VHDL) -- LIBRARY ieee; USE ieee.std_logic_1164.all; use IEEE.NUMERIC_STD.ALL; use IEEE.MATH_REAL.ALL; USE std.textio.all; USE ieee.std_logic_textio.all; ENTITY TB IS END TB; ARCHITECTURE test_arch OF TB IS constant clock_period : time := 10 ns; signal clk : std_logic := '0'; signal clock_running : std_logic := '0'; signal sim_done : std_logic := '0'; signal button : std_logic_vector(5 downto 1) := (others => '0'); signal key : std_logic_vector(31 downto 0) := (others => '0'); component buttonToKey port ( clk_50 : in std_logic; button : in std_logic_vector(5 downto 1); key: out std_logic_vector(31 downto 0) ); end component; begin DUT : buttonToKey port map ( clk_50 => clk, button => button, key => key ); /* Clock process */ clock_proc : process begin if(clock_running = '1') then wait for clock_period / 2; clk <= not clk; elsif(sim_done = '1') then wait; else wait for 20 ns; end if; end process; /* Test proc */ test_proc : process begin -- printf("Test proc\n"); -- printf("clock_period = %e\n", clock_period); clock_running <= '1'; wait for 20 * clock_period; for i in 1 to 4 loop button <= "10000"; for j in 1 to 25 loop wait for 10 * clock_period; end loop; button <= "00001"; wait for 2 * clock_period; end loop; clock_running <= '0'; sim_done <= '1'; -- printf("done\n"); wait; end process; END test_arch;
and DO file to run it:
transcript file "" transcript file transcript.log transcript on if {} { vdel -lib rtl_work -all } vlib rtl_work vmap work rtl_work vcom -2008 -work work {ButtonToKey.vhd} vcom -2008 -work work {button_test.vht} vsim -t 1ps -L altera -L lpm -L sgate -L altera_mf -L altera_lnsim -L fiftyfivenm -L rtl_work -L work -voptargs="+acc" TB # add wave * add wave "/TB/CLK" add wave "/TB/BUTTON" add wave -hex "/TB/KEY" add wave -unsigned "/TB/DUT/count" add wave -decimal "/TB/DUT/index" add wave "/TB/DUT/state" # set sim_time # puts $sim_time set t0 run -all set dt - $t0] puts $dt wave zoom full # set PrefMain(Editor) {C:/Windows/System32/notepad.exe} # edit transcript
and it works just fine:
https://www.alteraforum.com/forum/attachment.php?attachmentid=13409
Note the lines in the DO file that add internal signals to the waveform as Tricky suggested.
You must be doing something wrong in the way you run the simulation. In any event, now that I know I'm not crazy (regardless of what others think) my interest in the problem is over. Suffice it to say there are all sorts of issues with your code, but since it sounds like a school project you should figure it out yourself. Good luck.
