公告
17268 討論
SignalTap: Reordering Nodes
SparkyNZ
新貢獻者 III
1,315 檢視
Is it not possible to re-order nodes in the Data view once you set them up?
In the above example I would like to move sd_D and oData so that they are on adjacent rows for example.
I can't figure out how to do this via the GUI. I had a little play around with ordering the XML elements in the .stp file but haven't had any luck (yet).
0 積分
1 解決方案
SparkyNZ
新貢獻者 III
1,295 檢視
Thanks - that was the first thing that I tried.
Oh.. I see.. It's a bit buggy. Nothing will drag the first time it's clicked.
It's not until you select it first and then click again to drag that it works.
在原始文章中檢視解決方案
3 回應
sstrell
榮譽貢獻者 III
1,299 檢視
Just click and drag the nodes to reorder them.
#iwork4intel
SparkyNZ
新貢獻者 III
1,296 檢視
SyafieqS
員工
1,285 檢視
Hi Paul,
Click the node for selection, then click again and drag to which order you desire.
回覆
