17268 Discussions
Simulation in ModelSim Altera Starter Edition
Hi guys,
need a little bit help. I try ModelSim ALTERA STARTER EDITION 6.5b for the first time, have created a test project (two inputs, two outputs) and wanted to simulate it. My problem is – I can add my signals to the wave window, but I did not find a way to add a waveform to my signals in this window. I have used ModelSim SE PLUS before and in this program if I clicked with the right mouse button in the Objects window, I have got in the pull-up menu (upon other items) the “create wave” item. In the ModelSim Altera Starter Edition I see all these items too, except the “create wave” item. How can I add a waveform here?
Thank you
You have to drive signals from a testbench.
Tricky, thank you for your prompt answer.
Is it a extra limitation of ModelSim Altera Edition, that I have to obligatory use testbench and cannot add a waveform “on the fly” in the wave window?
I would recommend using a testbench to drive the inputs and to test the response of the outputs, but you could use the modelsim force command to drive your inputs.
I'm having the same problem described by the original post in this thread. I'm following the tutorial in Altera's ModelSim_GUI_Introduction.pdf and cannot access the "create wave" menu selection.
How do I create a testbench?
i think the Waveform Editor was only enabled in the latest ModelSim-A(S)E included with ACDS 10.1, version 6.6c
A testbench is just an HDL text file with signals to drive your unit under test. Simply instantiate your UUT, and create some behavioural signals. for example, to generate a clock in VHDL, you can simply do this:
signal clk : std_logic := '0';
clk <= not clk after 10 ns; --100 MHz clock.
and for stimulus:
process begin input <= 0; wait for 100 ns; input <= 1; wait for 500 ns; input <= 2; for 1 in 1 to 20 loop wait until rising_edge(clk); end loop; input <= 3; wait; end process;
This is just the tip of the iceburg
I'm using ModelSim 6.5b. So I won't be able to use the waveform editor at all in this version?
no, i don't think so
try Quartus II 10.1 and ModelSim 6.6c
and i agree about HDL test benches being proper work around. they aren't that bad :)
built a few templates (clocks, resets, from text file, to text file) and build test benches from the templates
Hi thepancake,
test benches are surely a good workaround and surely the most certain way to simulate a design, but sometimes one needs an opportunity for quick test without to have to write a new test bench. It is really a pity, that this feature is not implemented.
Apropos the test benches. I tried the following test bench with Quartus 9.1 SP2 :
library ieee ;
use ieee.std_logic_1164.all;
use ieee.numeric_bit.all;
use ieee.std_logic_unsigned.all;
use ieee.std_logic_textio.all;
use ieee.std_logic_arith.all;
use ieee.numeric_std.all;
library lpm;
use lpm.lpm_components.all;
library altera;
use altera.altera_primitives_components.all;
entity testbench_1 is
end testbench_1;
architecture test_1 of testbench_1 is
signal d : std_logic_vector(3 downto 0);
signal q : std_logic_vector(1 downto 0);
begin
dut: entity work.mv78200(behv1)
port map(d, q);
stimulus : process is
begin
d(0) <= '0';
d(1) <= '0';
d(2) <= '0';
d(3) <= '0';
wait for 500ns;
d(0) <= '1';
d(1) <= '1';
d(2) <= '1';
d(3) <= '1';
wait;
end process stimulus;
end architecture test_1;
and I got again and again the error message:
error (10533): vhdl wait statement error at testbench_1.vhd(43): wait statement must contain condition clause with until keyword.
(Line 43 is the statement "wait for 500ns;")
With ModelSim Altera Edition I can use this test bench without any problems. Any ideas?
You cannot compile test benches with quartus. Quartus only understands the "wait until" command for synthesising code. Test benches cannot be synthesised.
Secondly, do not use std_logic_arith and numeric_std in the same file.
Tricky, thanks for your information about Quartus.
You are right, it is not a good idea to use std_logic_arith and numeric_std together (have overlooked it as I copied parts of two different designs)
--- Quote Start ---
--- Quote End ---
Hello, I continue with this topic while my question is the same.
How can I use the waveforme editor with modelsim 6.6d ? I've tryed with the example (counter.v) but I cannot change the waves.
Hello all,
I am new to this software and trying to learn in my free time.
Can anyone tell me how to setup modelsim on Quartus -II? I have tried to follow the steps from the pdf file provided,but I cannot see the option of settings in bold under Assignment.
Is there any way I can open Modesim once I download Quartus-II?
Thanks all.
I finally figured it out to open Modelsim.
