17263 Discussions
Simulation problem of the PLL (27Mhz clock to 100Mhz clock)
DProk1
I use Cyclone V 5CEBA2F17A7.
the program I use is Quartus 17.1.
I have problem with setting a PLL (27Mhz clock to 100Mhz clock).
When I simulate the pll, I see gaps on the output clock (100Mhz).
settings:
input clock 27Mhz.
Output clock 100Mhz.
The setting of the pll are seen on the attached file (pic 1 and pic 2).
The simulation is in pic 3.
why there are gaps on the simulation and how do I fix this issue?
thank you
Rahul_S_Intel1
Hi ,
May I know what exactly Gap is meaning, do you use model sim for simulation
DProk1
I use Qeustasim...
you can see the gaps in the file that I added to the qeustion above.
it is in pic No.3 in the file.
