17268 Discussions
Sublime -> how to define it as External Preferable Editor?
amildm
Valued Contributor I
Hi All,
How should I define the Sublime as an Preferable Editor in Quartus?
Here is how I defined it:
Here is the message , which I receive each time when I double click on any file inside of the Quartus (e.g. HDL files):
 So, what's wrong? The Sublime Text Editor works fine as a stands alone editor, I'm also able to open the same files with it that I failed to open from Quartus.
Thanks!
RichardTanSY_Altera
I believe the problem occur if you close the Quartus and reopen it.
The double quote in the command line seem to be removed automatically, causing the tool can't find the tool.
Add back the double quote in the command line and it should works. Example:
"C:\Program Files\Sublime Text\sublime_text.exe"
Or copy the .exe to the Quartus installation path (without any space in between). Example:
C:\intelFPGA\sublime_text.exe (with or without the double quote)
RichardTanSY_Altera
RichardTanSY_Altera
Thanks for acknowledge the solution provided.
I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
Thank you.
Richard Tan
p/s: If any answer from the community or Intel Support are helpful, please feel free to give best answer or rate 9/10 survey.
