17245 Discussions
Suggesting a testbench for a design
Hello everyone, I have a simple (4x1) multiplexing system in VHDL that consists of the following files:
I would really be grateful if someone could provide me with a possible testbench. I can successfully Simulate the design using quartus ii simulator but I want to use (modelsim- altera) which requires a testbench. Thanks for your hlep.
1)
------------- VHDL description for a 4x1 Multiplexer ----------------------------
library ieee;
use ieee.std_logic_1164.all;
entity mux4 is
port (
I : in std_logic_vector (3 downto 0);
reset: in std_logic;
s : in std_logic_vector (1 downto 0);
y : out std_logic);
end mux4;
architecture behavior of mux4 is
begin
Design: process (reset,I,s)
begin
if reset = '0' then
y <= '0';
elsif s = "00" then
y <= I(0);
elsif s = "01" then
y <= I(1);
elsif s= "10" then
y <= I(2);
else
y <= I(3);
end if;
end process;
end behavior;
2)
---------------------- Frequency division by 2 -----------------------------------------
LIBRARY ieee;
USE ieee.std_logic_1164.all;
ENTITY freq_div2 IS
PORT ( clk : IN STD_LOGIC;
out2 : BUFFER STD_LOGIC);
END freq_div2;
ARCHITECTURE example OF freq_div2 IS
BEGIN
PROCESS (clk)
VARIABLE count2 : INTEGER RANGE 0 TO 7;
BEGIN
IF (clk'EVENT AND clk='0') THEN
count2 := count2 + 1;
IF (count2 = 1) THEN
out2 <= NOT out2;
count2 := 0;
END IF;
END IF;
END PROCESS;
END example;
3)
---------------------- Frequency division by 4 -------------------------------------------
LIBRARY ieee;
ENTITY freq_div4 IS
out4 : BUFFER STD_LOGIC);
END freq_div4;
ARCHITECTURE example OF freq_div4 IS
BEGIN
PROCESS (clk)
VARIABLE count4 : INTEGER RANGE 0 TO 7;
BEGIN
count4 := count4 + 1;
IF (count4 = 2) THEN
out4 <= NOT out4;
count4 := 0;
END IF;
END IF;
END PROCESS;
END example;
4)
---------------------- Frequency division by 6 --------------------------------------
LIBRARY ieee;
ENTITY freq_div6 IS
out6 : BUFFER STD_LOGIC);
END freq_div6;
ARCHITECTURE example OF freq_div6 IS
BEGIN
PROCESS (clk)
VARIABLE count6 : INTEGER RANGE 0 TO 7;
BEGIN
count6 := count6 + 1;
IF (count6 = 3) THEN
out6 <= NOT out6;
count6 := 0;
END IF;
END IF;
END PROCESS;
END example;
5)
---------------------- Frequency division by 12 -------------------
LIBRARY ieee;
ENTITY freq_div12 IS
out12 : BUFFER STD_LOGIC);
END freq_div12;
ARCHITECTURE example OF freq_div12 IS
BEGIN
PROCESS (clk)
VARIABLE count12 : INTEGER RANGE 0 TO 7;
BEGIN
count12 := count12 + 1;
IF (count12 = 6) THEN
out12 <= NOT out12;
count12 := 0;
END IF;
END IF;
END PROCESS;
END example;
6)
---------------------- Frequency division by 24 -------------------
LIBRARY ieee;
ENTITY freq_div24 IS
out24 : BUFFER STD_LOGIC);
END freq_div24;
ARCHITECTURE example OF freq_div24 IS
BEGIN
PROCESS (clk)
VARIABLE count24 : INTEGER RANGE 0 TO 15;
BEGIN
count24 := count24 + 1;
IF (count24 = 12) THEN
out24 <= NOT out24;
count24 := 0;
END IF;
END IF;
END PROCESS;
END example;
7)
------- Creating a package named (my_component) -------------------------
LIBRARY ieee ;
USE ieee.std_logic_1164.all ;
USE ieee.std_logic_unsigned.all ;
package my_component is
component freq_div2 is
port(
clk : in STD_LOGIC;
out2 : buffer STD_LOGIC
end component;
component freq_div4 is
port(
clk : in STD_LOGIC;
out4 : buffer STD_LOGIC
end component;
component freq_div6 is
port(
clk : in STD_LOGIC;
out6 : buffer STD_LOGIC
end component;
component freq_div12 is
port(
clk : in STD_LOGIC;
out12 : buffer STD_LOGIC
end component;
component freq_div24 is
port(
clk : in STD_LOGIC;
out24 : buffer STD_LOGIC
end component;
component mux4 is
port (
y: out std_logic);
end component;
end my_component;
8)
------------- Top-level structural description for the multiplexing system -----------
LIBRARY ieee ;
use work.my_component.all;
entity Mul_sys is
port (clk, reset : in std_logic;
y : out std_logic);
end Mul_sys;
architecture structural of Mul_sys is
signal n : std_logic_vector(4 downto 0);
begin
u0: freq_div2 port map (clk =>clk, out2 => n(0));
u1: freq_div4 port map (clk =>clk, out4 => n(1));
u2: freq_div6 port map (clk =>clk, out6 => n(2));
u3: freq_div12 port map (clk =>clk, out12 => n(3));
u4: freq_div24 port map (clk =>clk, out24 => n(4));
u5 : mux4 port map (I(0) => clk, I(1) => n(0), I(2) => n(1), I(3) => n(2), s(0)=> n(3), s(1)=> n(4), reset =>reset, y => y);
end structural;
Hello
You can look on the internet for books about fpga 's by pong chu.
In the VHDL versions, look for the term testbench.
You will find nice examples there.
The older book releases can be found online for free.
Johi.
