Hello everyone, I have a simple (4x1) multiplexing system in VHDL that consists of the following files:
I would really be grateful if someone could provide me with a possible testbench. I can successfully Simulate the design using quartus ii simulator but I want to use (modelsim- altera) which requires a testbench. Thanks for your hlep. 1) ------------- VHDL description for a 4x1 Multiplexer ---------------------------- library ieee; use ieee.std_logic_1164.all; entity mux4 is port ( I : in std_logic_vector (3 downto 0); reset: in std_logic; s : in std_logic_vector (1 downto 0); y : out std_logic); end mux4; architecture behavior of mux4 is begin Design: process (reset,I,s) begin if reset = '0' then y <= '0'; elsif s = "00" then y <= I(0); elsif s = "01" then y <= I(1); elsif s= "10" then y <= I(2); else y <= I(3); end if; end process; end behavior; --------------------------------------------------------------------------------------------------2) ---------------------- Frequency division by 2 ----------------------------------------- LIBRARY ieee; USE ieee.std_logic_1164.all; ----------------------------------------- ENTITY freq_div2 IS PORT ( clk : IN STD_LOGIC; out2 : BUFFER STD_LOGIC); END freq_div2; ----------------------------------------- ARCHITECTURE example OF freq_div2 IS BEGIN PROCESS (clk) VARIABLE count2 : INTEGER RANGE 0 TO 7; BEGIN IF (clk'EVENT AND clk='0') THEN count2 := count2 + 1; IF (count2 = 1) THEN out2 <= NOT out2; count2 := 0; END IF; END IF; END PROCESS; END example; ---------------------------------------------------------------------------------------------- 3)
---------------------- Frequency division by 4 ------------------------------------------- LIBRARY ieee; USE ieee.std_logic_1164.all; ----------------------------------------- ENTITY freq_div4 IS PORT ( clk : IN STD_LOGIC; out4 : BUFFER STD_LOGIC); END freq_div4; ----------------------------------------- ARCHITECTURE example OF freq_div4 IS BEGIN PROCESS (clk) VARIABLE count4 : INTEGER RANGE 0 TO 7; BEGIN IF (clk'EVENT AND clk='0') THEN count4 := count4 + 1; IF (count4 = 2) THEN out4 <= NOT out4; count4 := 0; END IF; END IF; END PROCESS; END example; ------------------------------------------------------------------------------------------ 4) ---------------------- Frequency division by 6 -------------------------------------- LIBRARY ieee; USE ieee.std_logic_1164.all; ----------------------------------------- ENTITY freq_div6 IS PORT ( clk : IN STD_LOGIC; out6 : BUFFER STD_LOGIC); END freq_div6; ----------------------------------------- ARCHITECTURE example OF freq_div6 IS BEGIN PROCESS (clk) VARIABLE count6 : INTEGER RANGE 0 TO 7; BEGIN IF (clk'EVENT AND clk='0') THEN count6 := count6 + 1; IF (count6 = 3) THEN out6 <= NOT out6; count6 := 0; END IF; END IF; END PROCESS; END example; -----------------------------------------
5) ---------------------- Frequency division by 12 ------------------- LIBRARY ieee; USE ieee.std_logic_1164.all; ----------------------------------------- ENTITY freq_div12 IS PORT ( clk : IN STD_LOGIC; out12 : BUFFER STD_LOGIC); END freq_div12; ----------------------------------------- ARCHITECTURE example OF freq_div12 IS BEGIN PROCESS (clk) VARIABLE count12 : INTEGER RANGE 0 TO 7; BEGIN IF (clk'EVENT AND clk='0') THEN count12 := count12 + 1; IF (count12 = 6) THEN out12 <= NOT out12; count12 := 0; END IF; END IF; END PROCESS; END example; ----------------------------------------- 6) ---------------------- Frequency division by 24 ------------------- LIBRARY ieee; USE ieee.std_logic_1164.all; ----------------------------------------- ENTITY freq_div24 IS PORT ( clk : IN STD_LOGIC; out24 : BUFFER STD_LOGIC); END freq_div24; ----------------------------------------- ARCHITECTURE example OF freq_div24 IS BEGIN PROCESS (clk) VARIABLE count24 : INTEGER RANGE 0 TO 15; BEGIN IF (clk'EVENT AND clk='0') THEN count24 := count24 + 1; IF (count24 = 12) THEN out24 <= NOT out24; count24 := 0; END IF; END IF; END PROCESS; END example; ----------------------------------------------------------------------------------- 7) ------- Creating a package named (my_component) ------------------------- LIBRARY ieee ; USE ieee.std_logic_1164.all ; USE ieee.std_logic_unsigned.all ; package my_component is component freq_div2 is port( clk : in STD_LOGIC; out2 : buffer STD_LOGIC ); end component; component freq_div4 is port( clk : in STD_LOGIC; out4 : buffer STD_LOGIC ); end component; component freq_div6 is port( clk : in STD_LOGIC; out6 : buffer STD_LOGIC ); end component; component freq_div12 is port( clk : in STD_LOGIC; out12 : buffer STD_LOGIC ); end component; component freq_div24 is port( clk : in STD_LOGIC; out24 : buffer STD_LOGIC ); end component; component mux4 is port ( I : in std_logic_vector (3 downto 0); s : in std_logic_vector (1 downto 0); reset: in std_logic; y: out std_logic); end component; end my_component; ----------------------------------------------------------------------------------------------- 8) ------------- Top-level structural description for the multiplexing system ----------- LIBRARY ieee ; USE ieee.std_logic_1164.all ; USE ieee.std_logic_unsigned.all ; use work.my_component.all; entity Mul_sys is port (clk, reset : in std_logic; y : out std_logic); end Mul_sys; architecture structural of Mul_sys is signal n : std_logic_vector(4 downto 0); begin u0: freq_div2 port map (clk =>clk, out2 => n(0)); u1: freq_div4 port map (clk =>clk, out4 => n(1)); u2: freq_div6 port map (clk =>clk, out6 => n(2)); u3: freq_div12 port map (clk =>clk, out12 => n(3)); u4: freq_div24 port map (clk =>clk, out24 => n(4)); u5 : mux4 port map (I(0) => clk, I(1) => n(0), I(2) => n(1), I(3) => n(2), s(0)=> n(3), s(1)=> n(4), reset =>reset, y => y); end structural;
Hello
You can look on the internet for books about fpga 's by pong chu. In the VHDL versions, look for the term testbench. You will find nice examples there. The older book releases can be found online for free. Best Regards, Johi.- Mark as New
