17238 Discussions
System Console JTAG connection issue: device_download_sof
Bodil
Hi Intel,
I am working with a testing system for an Altera MAX 10 board. The system is fairly simple, I am using a TCL script to run the test. The way it works is:
- The user interface is set ut through a "main" script
- A simple .sof is downloaded to the board to check the hardware ID
- A more sophisticated .sof with test features is then applied to run tests on the board.
I use the device_download_sof function and I always make sure to close all open services between calls to the fucntion. However, every second time I run system console the script fails on the second call to device_download_sof and prints out the following error:
mai 19, 2021 10:30:28 AM com.altera.debug.core
INFO: [INFO] Programming FPGA: /devices/10M50DA(.|ES)|10M50DC@1#USB-0 with \Users\ajb\system_console\scripts\production_test\trunk\E5248B02#00\1226.sof
SEVERE: device_download_sof: This device does not have a JTAG connection
SEVERE: java.lang.Exception: device_download_sof: This device does not have a JTAG connection
while executing
"device_download_sof $device $sof"
(procedure "board_test::jtag_upload_sof" line 134)
invoked from within
"board_test::jtag_upload_sof E5248B02#00"
java.util.concurrent.ExecutionException: java.lang.Exception: device_download_sof: This device does not have a JTAG connection
while executing
invoked from within
at com.altera.systemconsole.internal.core.SimpleFuture$Sync.innerGet(SimpleFuture.java:208)
at com.altera.systemconsole.internal.core.SimpleFuture.getInternal(SimpleFuture.java:88)
at com.altera.systemconsole.internal.core.SimpleFuture.get(SimpleFuture.java:61)
at com.altera.systemconsole.dashboard.internal.SystemConsoleDashboard$TCLDashboard$1$1.run(SystemConsoleDashboard.java:70)
at com.altera.systemconsole.internal.core.SystemExecutor$2.run(SystemExecutor.java:306)
at com.altera.systemconsole.internal.core.SystemExecutor$4.run(SystemExecutor.java:553)
at com.altera.systemconsole.internal.core.SystemExecutor$ComparableTask.run(SystemExecutor.java:151)
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
Caused by: java.lang.Exception: device_download_sof: This device does not have a JTAG connection
while executing
invoked from within
at com.altera.systemconsole.scripting.ScriptEngine$5.run(ScriptEngine.java:589)
at com.altera.tcl.interpreter.NativeTclWrapper.runEvent(NativeTclWrapper.java:341)
at com.altera.tcl.interpreter.NativeTclWrapper.doOneEvent0(Native Method)
at com.altera.tcl.interpreter.NativeTclWrapper.doOneEvent(NativeTclWrapper.java:355)
at com.altera.tcl.interpreter.NativeTCLInterpreter.waitAndDoOneEvent(NativeTCLInterpreter.java:436)
at com.altera.tcl.interpreter.InterpreterInstantiator$1.run(InterpreterInstantiator.java:59)
... 1 more
To make it even more complicated it fails consequently every second time.
Additionally, the testscript system worked fine a couple of years ago. I've spent a lot of time trying to find the issue and even called in the guy who made the system, but to no avail.
Bellow I provide all the measures I have taken to identify the problem:
  • All services are closed
  • I've tried both the Quartus Prime 20.1 and 16.1 versions
  • Power cycling the all HW connected to the system
  • Downloaded .sof from previous versions of the system
  • Deactivated the Altera jtagserver.exe
  • Replaced all HW components
  • Used different USB blasters
Host computer is running Win10 x64
FPGA is a Altera MAX10 10M50DAF48417G
The debug board uses a MCP2200 serial converter
Any ideas on how to fix this would be greatly appriciated.
A.
Bodil
I also tried the Quartus Prime Pro v21.1, this didn't change anything..
YuanLi_S_Intel
Hi, you mentioned that it works previously. Any idea what changes has been made?
Can you try with different HOST PC?
