17266 Discussions
SystemVerilog Interface Synthesis Quartus 13
Quartus 13 Synthesis has the limitation that interface attributes cannot be used conveniently in a module. I am looking for a work around as this limitation does not appear in other tools.
Given a simple SV interface definition:
interface avalon_bus #( parameter ADDR_WIDTH = 16, parameter DATA_WIDTH = 8 ) ( input logic clock, input logic reset ); // aliais/short-cut for address and data widths localparam AW = ADDR_WIDTH-1; localparam DW = DATA_WIDTH-1; localparam MaxAddress = 2**ADDR_WIDTH; logic address; logic writedata; logic readdata; modport per ( input clock, input reset, input address, input writedata, output readdata ); endinterface
and a module that uses the interface:
module avalon_mux ( interface bus ); localparam AddrThreshold = bus.MaxAddress/2; logic pipe_a, pipe_b; always @(posedge bus.clock) begin if (busin.address <= AddrThreshold) begin pipe_a <= bus.writedata; end else begin pipe_b <= bus.writedata; end end endmodule
Quartus throws errors because it does not like the use of the "hierarchy separator" in most expressions. Does anyone know of a work around? Example, is there another way to express / localparam AddrThreshold = bus.MaxAddress/2 /? I have tried / const integer / and some other hacks but no luck, yet :( I have also attached an example Quartus project.
Chris
TO_BE_DONE
Yes, something odd did happen. Your original post is no more!
Might it magically reappear or do I have to recreate the post?
Probably recreate it.
No it didn't disappear, it was automatically moderated down by the forum's overzealous spam detection system.
This is legal, but many not be supported by Quartus yet.
Try a continuous assignment
int AddrThreshold; assign AddrThreshold = bus.MaxAddress/2;
I was pleasantly surprised the continuous assignment worked
for the /AddrThreshold/ expression. But it doesn't work for the
other uses cases, like:
Best I can tell, I wont be able to use the parameters that are
part of the interface. I will need to reduplicate all the parameters
to the module:
module avalon_mux # ( MaxAddress = 16, DW = 16 ) ( interface bus ); localparam AddrThreshold = MaxAddress/2; logic pipe_a, pipe_b; always @(posedge bus.clock) begin if (busin.address <= AddrThreshold) begin pipe_a <= bus.writedata; end else begin pipe_b <= bus.writedata; end end endmodule
And then instantiate like:
avalon_mux # (MaxAddress=bus.MaxAddress, DW = bus.DW) M1(bus);
which partially defeats the purpose of using interfaces.
Chris
