17266 Diskussionen
create different clocks at Test Bench
Geehrter Beitragender II
1.200Aufrufe
Hi ,
i create 2 different clocks at Test Bench :
1. clk_25M - clk_period = 1/25 MHz = 40 nsec
1. clk_100M - clk_period = 1/100 MHz = 10 nsec
At Model Sim I see correct wave of clk_25M .
The wave of clk_100M is wrong , the wave start at '0' and after 45 nsec rise to '1' and after 45 nsec fall to '0' for 5 nsec and repeate .
why is that ?
Test Bench file and waves pictures attached .
2 Antworten
491Aufrufe
thats because the 100 MHZ clock wont change until after the 25MHz clock has changed. You need to put the two clocks in separate processes.
491Aufrufe
Thanks , i learned new thing .
Antworten
