17254 Discussions
The error in modelsim " Types do not match between component and entity for port "a". Again, I think the testbench is correct. Thanks
NMuth3
library ieee;                -- line 1
use ieee.std_logic_1164.all;         -- line 2
                       -- line 3
entity find_errors is port(           -- line 4
  a: in std_logic_vector(0 to 3);          -- line 5
  b: out std_logic_vector(3 downto 0);     -- line 6
  c: in std_logic_vector(5 downto 0));      -- line 7
end find_errors;               -- line 8
                       -- line 9
architecture not_good of find_errors is     -- line 10
 begin                   -- line 11
 my_label: process(a)             -- line 12
  begin                  -- line 13
  if c <= x"F" then             -- line 14
   b <= a;                -- line 15
  else                   -- line 16
   b <= "0101";              -- line 17
  end if;                  -- line 18
 end process;                -- line 19
end not_good;                 -- line 20
RichardTanSY_Altera
Could you help to share your quartus project so I can look into it, including the testbench?
