Could anyone tell me what causes this happen to my code?
After compilation, I got clk Slack -4.076 and End Point TNS -73.368; All the stuff under the minimum Pulse width:'clk' report is in red...also the same thing for setup summary. Thanks in advance...
module memory(clk,mem_oe,mem_rw,addr,mem_data);
input clk,mem_oe,mem_rw;
//mem_oe=1 for memory output enable, mem_oe=0 output=ZZZZ...
//mem_rw=0 for read, mem_rw=1 for write
input addr;
inout mem_data;
wire mem_data;
reg ram;
reg data_out;
//integer i;
assign mem_data = (!mem_rw&&mem_oe) ? data_out : 18'bz;
always@(posedge clk)
begin
if(!mem_rw) // read from the memory
begin
data_out<=ram;
end
else // write to the memory
begin
ram <= mem_data;
end
end
endmodule
by the way, in the simulation, this circuits does work.
And im quite confused about this kind of timing requirements warnings.- Mark as New
How long are mem_rw and mem_oe pulses?
If they are asserted more than one clock period you simply need to define a multicycle path.- Mark as New
This does not look like a problem with the code.
It looks like you're imposing a too high clock frequency to your design. Which is the clock frequency that you impose to your design? Do things work if you reduce the clock frequency to very small value?- Mark as New
--- Quote Start --- This does not look like a problem with the code. It looks like you're imposing a too high clock frequency to your design. Which is the clock frequency that you impose to your design? Do things work if you reduce the clock frequency to very small value? --- Quote End --- Hi, I don't know if i did impose any clock frequency to my design. Is there like a default clock frequency that's imposed when compilation?
After the compile, run TimeQuest. Double click "Report Clocks" and make sure your clock frequency is what you specified it to be. You can also run "Report Unconstrained Paths" and if your clock is not constrained, it will show up there. I am assuming you constrained your clock. If you did not, create a .sdc file to constrain the clock.
--- Quote Start --- After the compile, run TimeQuest. Double click "Report Clocks" and make sure your clock frequency is what you specified it to be. You can also run "Report Unconstrained Paths" and if your clock is not constrained, it will show up there. I am assuming you constrained your clock. If you did not, create a .sdc file to constrain the clock. --- Quote End --- Hi, I assume that you run the simulation with your RTL code. This simulation did not take into account any delay which you will have later on when the design is implemented in the FPGA. What you test with this simulation is the function of your design. But in the FPGA you will delays between your registers ( routing delay and cell delay). These delays limits the maximum frequency which you can use running your design. You always constraint your clocks, because Quartus needs this for opitimizing your design in the right way. Kind regards GPK
if you do not create any clock, Timequest automatically creates a clock with a frequency of 1GHz and analyzes timings with this clock.- Mark as New
Got it. Thanks for you guys.
