Hello
I has create a symbol with the toplevel from the 5 megapixel demo project TRDB_D5M_CD_v1.0 for DE2 Board. But when I insert the symbol in a block diagram and sets the Input/Output, after the synthese I have timing violation and the VGA-Monitor d'ont display a perfect image. The same problem I have with the video demo on the Terasic CD DE2_TV. In the attachment you find the two demo project, could you try on your system? Maybe your found the problem.... For any tips I thanks....Link Copied
--- Quote Start --- Hello I has create a symbol with the toplevel from the 5 megapixel demo project TRDB_D5M_CD_v1.0 for DE2 Board. But when I insert the symbol in a block diagram and sets the Input/Output, after the synthese I have timing violation and the VGA-Monitor d'ont display a perfect image. The same problem I have with the video demo on the Terasic CD DE2_TV. In the attachment you find the two demo project, could you try on your system? Maybe your found the problem.... For any tips I thanks.... --- Quote End --- Hi, in which of the projects I should find your BDF-file ? Kind regards GPK
If you can do a "report_timing" in TimeQuest on the worst case failing path, we can help troubleshoot more directly. WHen you get the spreadsheet report, just go to File -> Export and export a .csv or .xls.
First check that the source and destination clocks are synchronous and phase aligned. Mike- Mark as New
can you make the bdf file yourself, --> open toplevel verilog code and then File\Create_Update\Create Symbol for Files from current Files. Then open New\Block Diagram Insert Symbol\right button mouse on Symbol and Create Inputs with right Assignment. And then RUN Synthese. Sorry, I don't can upload the entire project, size to big.... I hope you find 10 minutes for this... Thanks you very much...- Mark as New
I have resolved the problem.
I export the Pin Assignment from the original DE2_TV inclusive the "Export back-annotated routing" and "Save a node-level netlist of the entire design into a persistant source file" yeppaaaa.. it works well now. I have also make a SopC Symbol and include it now I can make my camera tracking... Thanks a lot...- Mark as New
Hey, Antonio,
So, what happened here? Possibly you were getting Fitter assigned pin placements. That's why back-annotation would fix it. Something else? Mike- Mark as New
yes... :confused:
or can you specify your question? sorry I don't understand what you mean...
Topic Options
