17257 Discussions
Trouble compiling my JK flip flop VHDL code!? "Syntax Error"
--The below code doesn't compile. I am given the following errors. Could someone help me troubleshoot this.
--ERRORS:
Error (10500): VHDL syntax error at lab4_jke.vhd(14) near text "if"; expecting "end", or "(", or an identifier ("if" is a reserved keyword), or a concurrent statement
Error (10500): VHDL syntax error at lab4_jke.vhd(14) near text "then"; expecting "<="
Error (10500): VHDL syntax error at lab4_jke.vhd(15) near text "then"; expecting "<="
Error (10500): VHDL syntax error at lab4_jke.vhd(17) near text "elsif"; expecting "end", or "(", or an identifier ("elsif" is a reserved keyword), or a concurrent statement
Error (10500): VHDL syntax error at lab4_jke.vhd(17) near text "then"; expecting "<="
Error (10500): VHDL syntax error at lab4_jke.vhd(19) near text "elsif"; expecting "end", or "(", or an identifier ("elsif" is a reserved keyword), or a concurrent statement
Error (10500): VHDL syntax error at lab4_jke.vhd(19) near text "then"; expecting "<="
Error (10500): VHDL syntax error at lab4_jke.vhd(21) near text "elsif"; expecting "end", or "(", or an identifier ("elsif" is a reserved keyword), or a concurrent statement
Error (10500): VHDL syntax error at lab4_jke.vhd(21) near text "then"; expecting "<="
Error (10500): VHDL syntax error at lab4_jke.vhd(23) near text "if"; expecting ";", or an identifier ("if" is a reserved keyword), or "architecture"
--CODE:
LIBRARY IEEE;
USE IEEE.STD_LOGIC_1164.ALL;
USE IEEE.STD_LOGIC_ARITH.ALL;
USE IEEE.STD_LOGIC_UNSIGNED.ALL;
ENTITY lab4_jke IS
PORT(
S,R,J,K,CLK : IN STD_LOGIC;
Q : OUT STD_LOGIC;
NQ : OUT STD_LOGIC);
END lab4_jke;
ARCHITECTURE behavior OF lab4_jke IS
BEGIN
if (CLK'EVENT AND CLK='1') then
if (J='0' AND K='0') then
Q <= Q;
elsif (J='1' AND K='0') then
Q <= '1';
elsif (J='0' AND K='1') then
Q <= '0';
elsif (J='1' AND K='1') then
Q <= NOT(Q);
END if;
END if;
END behavior;
LIBRARY IEEE;
ENTITY lab4_jke IS
PORT(
Q : OUT STD_LOGIC;
END lab4_jke;
BEGIN
process(clk)
begin
Q <= Q;
Q <= '1';
Q <= '0';
Q <= NOT(Q);
END if;
END if;
end process;
END behavior;
How can I incorporate the functionality of S "Set" and R "Reset" into my code?
A JK flip-flop doesn't have Set and Reset inputs. may be you want a preset and clear asynchronous inputs. In a FPGA you do that with a single asynchronous reset:
process(clr, clk)
begin
if( clr = '1' ) then
q_reg <= '0';
elsif( clk'event and clk = '1' ) then
q_reg <= q_next;
end if;
end process;
q_next <= '0' when ( j = '0' and k = '1' ) else ....etc
