17266 Discussions
Trouble running OpenCL hellowworld example on Arria10Gx board
I am trying to compile and run hello_world example of OpenCL SDK on Arria10Gx development board. Example fails to run with below error code. kindly check below steps and comment on any wrong doing.
user@user:~/opencl_examples/hello_world$ bin/host
Querying platform for info:
CL_PLATFORM_NAME = Intel(R) OpenCL
CL_PLATFORM_VENDOR = Intel(R) Corporation
CL_PLATFORM_VERSION = OpenCL 2.0
Querying device for info:
CL_DEVICE_NAME = Intel(R) Core(TM) i7-6800K CPU @ 3.40GHz
CL_DEVICE_VENDOR = Intel(R) Corporation
CL_DEVICE_VENDOR_ID = 32902
CL_DEVICE_VERSION = OpenCL 2.0 (Build 475)
CL_DRIVER_VERSION = 1.2.0.475
CL_DEVICE_ADDRESS_BITS = 64
CL_DEVICE_AVAILABLE = true
CL_DEVICE_ENDIAN_LITTLE = true
CL_DEVICE_GLOBAL_MEM_CACHE_SIZE = 262144
CL_DEVICE_GLOBAL_MEM_CACHELINE_SIZE = 64
CL_DEVICE_GLOBAL_MEM_SIZE = 16734322688
CL_DEVICE_IMAGE_SUPPORT = true
CL_DEVICE_LOCAL_MEM_SIZE = 32768
CL_DEVICE_MAX_CLOCK_FREQUENCY = 3400
CL_DEVICE_MAX_COMPUTE_UNITS = 12
CL_DEVICE_MAX_CONSTANT_ARGS = 480
CL_DEVICE_MAX_CONSTANT_BUFFER_SIZE = 131072
CL_DEVICE_MAX_WORK_ITEM_DIMENSIONS = 3
CL_DEVICE_MEM_BASE_ADDR_ALIGN = 1024
CL_DEVICE_MIN_DATA_TYPE_ALIGN_SIZE = 128
CL_DEVICE_PREFERRED_VECTOR_WIDTH_CHAR = 1
CL_DEVICE_PREFERRED_VECTOR_WIDTH_SHORT = 1
CL_DEVICE_PREFERRED_VECTOR_WIDTH_INT = 1
CL_DEVICE_PREFERRED_VECTOR_WIDTH_LONG = 1
CL_DEVICE_PREFERRED_VECTOR_WIDTH_FLOAT = 1
CL_DEVICE_PREFERRED_VECTOR_WIDTH_DOUBLE = 1
Command queue out of order? = true
Command queue profiling enabled? = true
Using AOCX: hello_world.aocx
Context callback: clCreateProgramWithBinary failed
ERROR: CL_INVALID_BINARY
Failed to create program with binary
Steps I followed are :
1. Installed and setup Intel OpenCL SDK for FPGA.
2. Configured Arria10Gx development kit as per instructions specified in document
https://www.altera.com/en_us/pdfs/literature/an/an807.pdf
3. compiled OpenCL kernel with below command and generated hello_world.aocx file.
aoc device/hello_world.cl -o bin/hello_world.aocx -board a10gx
4. compiled host program with make command
5. used "bin/host" command to run host program.
Also here is the info about detected devices
user@user:~/opencl_examples/hello_world$ aoc -list-boards
Board list:
a10gx
Board Package: /home/mobiliya/intelFPGA_pro/17.1/hld/board/a10_ref
a10gx_hostch
Channels: host_to_dev, dev_to_host
regards
Vinod
