I am trying to compile and run hello_world example of OpenCL SDK on Arria10Gx development board. Example fails to run with below error code. kindly check below steps and comment on any wrong doing. We purchased Arria 10Gx development kit from Digikey and with that we received Quartus Prime Pro software Licence. My setup is: Host machine - Ubuntu16.04 Quartus version - 17.1.0 aoc version - 17.1.0 user@user:~/opencl_examples/hello_world$ bin/host Querying platform for info: ========================== CL_PLATFORM_NAME = Intel(R) OpenCL CL_PLATFORM_VENDOR = Intel(R) Corporation CL_PLATFORM_VERSION = OpenCL 2.0 Querying device for info: ======================== CL_DEVICE_NAME = Intel(R) Core(TM) i7-6800K CPU @ 3.40GHz CL_DEVICE_VENDOR = Intel(R) Corporation CL_DEVICE_VENDOR_ID = 32902 CL_DEVICE_VERSION = OpenCL 2.0 (Build 475) CL_DRIVER_VERSION = 1.2.0.475 CL_DEVICE_ADDRESS_BITS = 64 CL_DEVICE_AVAILABLE = true CL_DEVICE_ENDIAN_LITTLE = true CL_DEVICE_GLOBAL_MEM_CACHE_SIZE = 262144 CL_DEVICE_GLOBAL_MEM_CACHELINE_SIZE = 64 CL_DEVICE_GLOBAL_MEM_SIZE = 16734322688 CL_DEVICE_IMAGE_SUPPORT = true CL_DEVICE_LOCAL_MEM_SIZE = 32768 CL_DEVICE_MAX_CLOCK_FREQUENCY = 3400 CL_DEVICE_MAX_COMPUTE_UNITS = 12 CL_DEVICE_MAX_CONSTANT_ARGS = 480 CL_DEVICE_MAX_CONSTANT_BUFFER_SIZE = 131072 CL_DEVICE_MAX_WORK_ITEM_DIMENSIONS = 3 CL_DEVICE_MEM_BASE_ADDR_ALIGN = 1024 CL_DEVICE_MIN_DATA_TYPE_ALIGN_SIZE = 128 CL_DEVICE_PREFERRED_VECTOR_WIDTH_CHAR = 1 CL_DEVICE_PREFERRED_VECTOR_WIDTH_SHORT = 1 CL_DEVICE_PREFERRED_VECTOR_WIDTH_INT = 1 CL_DEVICE_PREFERRED_VECTOR_WIDTH_LONG = 1 CL_DEVICE_PREFERRED_VECTOR_WIDTH_FLOAT = 1 CL_DEVICE_PREFERRED_VECTOR_WIDTH_DOUBLE = 1 Command queue out of order? = true Command queue profiling enabled? = true Using AOCX: hello_world.aocx Context callback: clCreateProgramWithBinary failed ERROR: CL_INVALID_BINARY Location: ../common/src/AOCLUtils/opencl.cpp:392 Failed to create program with binary Steps I followed are : ------------------------ 1. Installed and setup Intel OpenCL SDK for FPGA. 2. Configured Arria10Gx development kit as per instructions specified in document https://www.altera.com/en_us/pdfs/literature/an/an807.pdf 3. compiled OpenCL kernel with below command and generated hello_world.aocx file. aoc device/hello_world.cl -o bin/hello_world.aocx -board a10gx 4. compiled host program with make command 5. used "bin/host" command to run host program. Also here is the info about detected devices user@user:~/opencl_examples/hello_world$ aoc -list-boards Board list: a10gx Board Package: /home/mobiliya/intelFPGA_pro/17.1/hld/board/a10_ref a10gx_hostch Board Package: /home/mobiliya/intelFPGA_pro/17.1/hld/board/a10_ref Channels: host_to_dev, dev_to_host Thanks. regards VinodLink Copied
