17267 Discussions
problem running hello world example on Arria10Gx development kit
I am trying to compile and run hello_world example of OpenCL SDK on Arria10Gx development board. Example fails to run with below error code. kindly check below steps and comment on any wrong doing. We purchased Arria 10Gx development kit from Digikey and with that we received Quartus Prime Pro software Licence.
My setup is:
Host machine - Ubuntu16.04
Quartus version - 17.1.0
aoc version - 17.1.0
user@user:~/opencl_examples/hello_world$ bin/host
Querying platform for info:
CL_PLATFORM_NAME = Intel(R) OpenCL
CL_PLATFORM_VENDOR = Intel(R) Corporation
CL_PLATFORM_VERSION = OpenCL 2.0
Querying device for info:
CL_DEVICE_NAME = Intel(R) Core(TM) i7-6800K CPU @ 3.40GHz
CL_DEVICE_VENDOR = Intel(R) Corporation
CL_DEVICE_VENDOR_ID = 32902
CL_DEVICE_VERSION = OpenCL 2.0 (Build 475)
CL_DRIVER_VERSION = 1.2.0.475
CL_DEVICE_ADDRESS_BITS = 64
CL_DEVICE_AVAILABLE = true
CL_DEVICE_ENDIAN_LITTLE = true
CL_DEVICE_GLOBAL_MEM_CACHE_SIZE = 262144
CL_DEVICE_GLOBAL_MEM_CACHELINE_SIZE = 64
CL_DEVICE_GLOBAL_MEM_SIZE = 16734322688
CL_DEVICE_IMAGE_SUPPORT = true
CL_DEVICE_LOCAL_MEM_SIZE = 32768
CL_DEVICE_MAX_CLOCK_FREQUENCY = 3400
CL_DEVICE_MAX_COMPUTE_UNITS = 12
CL_DEVICE_MAX_CONSTANT_ARGS = 480
CL_DEVICE_MAX_CONSTANT_BUFFER_SIZE = 131072
CL_DEVICE_MAX_WORK_ITEM_DIMENSIONS = 3
CL_DEVICE_MEM_BASE_ADDR_ALIGN = 1024
CL_DEVICE_MIN_DATA_TYPE_ALIGN_SIZE = 128
CL_DEVICE_PREFERRED_VECTOR_WIDTH_CHAR = 1
CL_DEVICE_PREFERRED_VECTOR_WIDTH_SHORT = 1
CL_DEVICE_PREFERRED_VECTOR_WIDTH_INT = 1
CL_DEVICE_PREFERRED_VECTOR_WIDTH_LONG = 1
CL_DEVICE_PREFERRED_VECTOR_WIDTH_FLOAT = 1
CL_DEVICE_PREFERRED_VECTOR_WIDTH_DOUBLE = 1
Command queue out of order? = true
Command queue profiling enabled? = true
Using AOCX: hello_world.aocx
Context callback: clCreateProgramWithBinary failed
ERROR: CL_INVALID_BINARY
Failed to create program with binary
Steps I followed are :
1. Installed and setup Intel OpenCL SDK for FPGA.
2. Configured Arria10Gx development kit as per instructions specified in document
https://www.altera.com/en_us/pdfs/literature/an/an807.pdf
3. compiled OpenCL kernel with below command and generated hello_world.aocx file.
aoc device/hello_world.cl -o bin/hello_world.aocx -board a10gx
4. compiled host program with make command
5. used "bin/host" command to run host program.
Also here is the info about detected devices
user@user:~/opencl_examples/hello_world$ aoc -list-boards
Board list:
a10gx
Board Package: /home/mobiliya/intelFPGA_pro/17.1/hld/board/a10_ref
a10gx_hostch
Channels: host_to_dev, dev_to_host
regards
Vinod
