17268 Discussions
Trouble with "Convert Programming Files..." in Quartus II 13.1.4
on0308
Hello
When I generate a .cof file with "Save Conversion Setup..." in "Convert Programming Files...",
the contents of "Advanced options..." are not output.
What is the solution?
By the way, in Quartus Prime 17.1 etc., the contents are output without any problem.
Therefore, as an alternative, the contents output by Quartus Prime are copied to the .cof file generated by Quartus13.1.4.
AR_A_Intel
Yes, your understanding is correct.
AR_A_Intel
Hello
Welcome to INTEL forum. As I understand it, the “Advanced options” is not supported in Quartus13.1.4. version. It is advice to use the latest version of Quartus that support it. example v17.1. Thanks
on0308
Hello
Thank you for your answer.
That means that in the .cof file,
<cof>
    <advanced_options>
        <ignore_epcs_id_check>1</ignore_epcs_id_check>
    </advanced_options>
</cof>
Even if you add something like that and convert it, the "advanced options" setting will be ignored, right?
Best regards
AR_A_Intel
on0308
I understand.
Thanks a lot.
AR_A_Intel
Thanks for your update, hope all is well. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you
