Two Modelsim windows
I'm using Modelsim for my VHDL simulations and I'd like to compare two different designs. Is there a way to have two different simulation windows?
No, modelsim will only run a single design loaded at a time
But you can run modelsim multiple times if you have access to enough licences.
Hi
You can also instantiate the 2 designs in a single testbench & compare their results.
